Guys help me out with this r34 its got a nur engine bnr34401083
You sure it's got a N1 Engine (Nur)? Unless it's had an engine replacement?
R34 GTR V-Spec II Nur's only came in 6 colours:
Millennium Jade (JW0) / Bayside Blue (TV2) / Pearl White (QX1) / White (QM1) / Sparkling Silver (WV2) / Pearl Black (GV1)
The VIN you posted says = KV2 - Athlete Silver
And I believe the VIN is for a R34 GTR V-Spec II (Stock RB26DETT) as it states it has larger rear rotors.
The Build Date is March, 2001 and V-Spec II Nur's were built from February 2002.
Unless it's a V-Spec N1 or a V-Spec II N1 but from memory they only came in Crystal White (326).
100% sure its a nur engine took out the plugs and it has AB0 pistons which are nur spec, 05u head with a 24u block
ECR33112614
Thanks guys
Ok sure, that was my next question about the Block Number.
Pics of the engine?
Cant see the turbos to see if its got the n1 turbos
Yeah again, check the part number for the turbos, thanks.
Hi could you please check this Vin for me.
BNR32222923
would like to know paint code?
V-spec or not?
if possible to tell if its a pull type or pust gearbox
thank you
KostaGTR
Looks to be Base Model
Colour is Gun Metal Grey
From memory, it was either late '92 or '93 were Pull Types...
Hi there can I please get this vins details
6U9000ECR33106944
thank you very much
Hi, could you check this VIN for me please?
BCNR33005555
V-spec or base model
Model no. has a "Q"
"W" would be a V-spec
Anyone can confirm
No VIN Match, check the number or take a photo of blue plate and lets have a look, thanks.
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
