Guys help me out with this r34 its got a nur engine bnr34401083
You sure it's got a N1 Engine (Nur)? Unless it's had an engine replacement?
R34 GTR V-Spec II Nur's only came in 6 colours:
Millennium Jade (JW0) / Bayside Blue (TV2) / Pearl White (QX1) / White (QM1) / Sparkling Silver (WV2) / Pearl Black (GV1)
The VIN you posted says = KV2 - Athlete Silver
And I believe the VIN is for a R34 GTR V-Spec II (Stock RB26DETT) as it states it has larger rear rotors.
The Build Date is March, 2001 and V-Spec II Nur's were built from February 2002.
Unless it's a V-Spec N1 or a V-Spec II N1 but from memory they only came in Crystal White (326).
100% sure its a nur engine took out the plugs and it has AB0 pistons which are nur spec, 05u head with a 24u block
ECR33112614
Thanks guys
Ok sure, that was my next question about the Block Number.
Pics of the engine?
Cant see the turbos to see if its got the n1 turbos
Yeah again, check the part number for the turbos, thanks.
Hi could you please check this Vin for me.
BNR32222923
would like to know paint code?
V-spec or not?
if possible to tell if its a pull type or pust gearbox
thank you
KostaGTR
Looks to be Base Model
Colour is Gun Metal Grey
From memory, it was either late '92 or '93 were Pull Types...
Hi there can I please get this vins details
6U9000ECR33106944
thank you very much
Hi, could you check this VIN for me please?
BCNR33005555
V-spec or base model
Model no. has a "Q"
"W" would be a V-spec
Anyone can confirm
No VIN Match, check the number or take a photo of blue plate and lets have a look, thanks.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
