Goes in on the 12th. Let's see what these baby -5's will do at 2 bar haha.
I just bought a set of LM GT1's in 18 X 10 + 12 for it. :D
Haha awesome! Been hanging to see how this badboy hauls ;) I wanna ride in this thing!
Ride? Pfft... Take the keys. Just don't bend it :P
PS. I have two sets of those pipes for you to modify if you're intersted?
Oooooooooooo i think i almost jizzed! :woot: I will be treating it with the respect it deserves man. Yeah for sure dude always need some extra cash :thumbsup:
Just launch it hahah.
Yeah sweet. Dunno when i'll get them to you. haha.
A few of the sperm whale today after a wash.
Really lovely Paul!
...but I thought you liked your women 'dirty'!
* rear blade tilt indicates strong downforce
* downforce indicates traction
* traction indicates a need for speed
* a need for speed indicates the driver is serious
Paul serious? Yeah that fits!
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
