Few of as it sits in its most current for but without all the dust it's now covered in, last few are how it was when I got it, only things still on it from purchase are the fpr and boost controller
Those wheels look familiar :D Don't see many with buddy clubs. What size tyres are you running? Get much scrubbage?
Edited by GotsWapan
When I first found my wheels for sale I the was looking for 33s with them fitted and pretty sure I found a pic of yours, looks really clean
Thanks mate. Coping well with the 265's with unrolled guards at the moment haha. Would love smaller wheels with a deeper offset though
Mine are 10" +25 on rear but would like to go 17 or 18 with semis as might be looking to get a bit more track orientated although nytskys 33 with the drag wheels looks awesome
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
