16 minutes ago, r32-25t said:
How many people in the world have the set?
I believe that 2 people have 2/3 Brett
I consider myself most fortunate because...
* I hadn't been actively looking for the BCNR33
* I really wasn't disenchanted, despite having knocked back six beforehand
* I was fatalistic, thinking, "If it happens, it happens"
* This one was cleaner than the BNR32 despite the 32R having half the Kms
* Iron Chef had two of us Aussie buyers, and Kristian stated that if we were the last two standing, he wasn't going to permit a bun-fight between us. And therefore, he asked each of us to put in a silent bid - and only one bid. It just so happened that other bidders (for this Grade 4B car), dropped off and we here in Oz were the last ones standing after all.
  • Like 4
I took the silencer off and the RB sound is still there despite a turbo back titanium system.
It certainly is loud though. I hope there's no droning noise. I'll find out in a couple of days.
Thanks for looking. I'll leave all the c/f bits on it (fake or real) for a little while and see if I can get my head around it.
OS Giken triple is vicious. But I've found a li'l sweet spot where the car can be gently eased forward from a stopped position. Hill starts are a bugger. Lol
  • Like 2
KISS Method for a collectible
9 days, the Repair Shed for 400R c/f rear wing and 400R side skirts and Series 3 front lip paint/fit
2 weeks 100,000Km Service with Nismo odds and ends fitted.
4 weeks detailer
6 weeks tuner
Thanks for asking...
  • Like 1
6 hours ago, BLUBYU said:
Just purchased this one about a month ago, needs a head gasket. 25/30 325 kw at the wheels
Beautiful blue... Do you know what color is used? E.g. from what?
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
