  • 1 month later...
  • 3 months later...
  • 1 month later...
  • 2 months later...
  • 2 months later...
  • 2 months later...
  • 6 months later...
On 2/2/2015 at 8:22 PM, turb33gtst said:
My 1996 R33 GTST S2
just cleaned
a little extra colour
my r33 gtst
Look it. Nice and clean with no rice factors such as stickers and big wings.
Do you have the undercarriage neons too? Also what rims?
1 minute ago, pogman said:
Hmmm very strange on my screen its saying i posted them all twice. Do these work?20180824_170820.thumb.jpg.602ee1b10b9bdcIMG_20180901_202025_571.thumb.jpg.d57f1cIMG_20180629_142836_452.thumb.jpg.011e93IMG_20180616_133956_564.thumb.jpg.572efc
Still cannot see anything and clicking on the pictures doesn't open anything.
1 hour ago, pogman said:
Let me try the 1 to see if that works? I dont understand why its not working aiIMG_20180629_142836_452.thumb.jpg.ac202e
Nope sorry. How did you upload the photos? Don't do it on your phone unless you got it uploaded to a host website.
Ahhh ok im doing it from my phone but i never had an issur uploading from my phone before? And i tried both from my gallery and as an attachment
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
