Nissan Fast
hey, im new around here but was wondering if someone could decode this for me:
Chassis - HCR32-011224
Model - RCR32GASLM IC
COL? - KG1 G
I can't manage to get the FASt software! but from what i read above that this should be an automatic but its a manual. wondering if anything else has changed! (just looking at buying the car)
Thanks in advance
Anthony
South:
The vehicle deatils are as follows:
Build Date: 07/1989
Colour Code: KG1
Interior: G
Spec: M-Spec
Trans: Auto
Thanks very much for the info :D
Im taking that the KG1 is the silver colour? they must have done a switch on the transmision which makes me worry about the motor and the k's!
Anthony
i think it has EVERY nissan ever made on them, you just need the correct cd, each cd does different cars .. i'll try find out which cd has the datsun 1600 510 series for you ..
I do not have a C:/WINDOWS/directory, I followed the steps to what i could understand it. I put the NSFASTKY.INI file in C:/ .
Is this the same thing?
PS: I',m using XP
not c:windowsdirectory
its supposed to read put it in c:windows
(windows directory) he added a by mistake after windows (typo)
Got that sorted last week :D
It covers from 1979 and onwards.
Bnr32
100315
Kbnr32rxfslra
R32 = Chassis
91/07 = Year
Kh2 = Color
2k = Engine
Rb26dtt = Engine Type
Hi.4wd = Trans
Gt-r = Model
Mt
Ok,
Does that mean the car was manufactured in 1991 in july? That can't be right?
nOOSE
yes thats exactly what it means......which might be a problem for compliance or 15yo import if its not in the country yet
Then something is going on. coz i am importing this under the 15 year rule becoz it's suppose to be a 1990 may GTR.
it has already got import approval could that date be wrong?
nOOSE
I was hoping that someone can help me out also (have embarrassing dial up in the country which is very slow)
ECR33-051375
GGKBRTR33VDA-U---
I know what the bulk of the model numbers are but not sure on the last few digits are -U---
my rego papers say it is a 1995 my Green plate say 11/1994 and I just need to know if the car is series 1 or series 1.5
greatly appricaited
ECR33-051375
GGKBRTR33VDA-U---
greatly appricaited
It was made in 93/08 - so it's actually a 1993 car!
Edit: Cancel that - I think I screwed up entering the code!
Ian
ohh and you got me all excited then thinking someone mght have an answer for me ;)
Sorry about that.
When I type yhe number in that you gave (ECR33-051375) it comes back with "model series can not be found for this vin no"
The one that I actuall commented on was ECR33-005137 - I'd left the five of the end, and had an extra zero at the front.
Are sure your number is correct and that you don't have a digit wrong????
Ian
done it several times - the number either side are ok ie - 051374 is a GTS25T manual, with a rb25det, 2wd,QM1 color... 051376 is exactly the same, but 051375 can not be found - so if that is a correct number, it may not be a ECR33 ??
Ian
    • Awesome to know. I have a Series 1, and When pulling my front bumper off for the first time i realised my reo/crash bar was a bit worse for wear, and was going to try pick up a better one soon just so i can replace it. Someone is selling a full series 2 front bar and brackets for a decent price, so was going to probably reuse my brackets and install the new second hand reo/crash bar. I also have a genuine Altia body kit to do up, spray and put on, and not sure if that will use the series 1 or series 2 brackets for the front bumper, so having both will be handy, and knowing i can drill holes out to make stuff fit between series is also handy to know!
    • I should also say that the while they are different the only parts that matter are the center headlight supports and center bar from S1 to S2. The center bar will work, but the S1 has holes that clips go through into the S1 bumper. So if you were super cheap you could simply drill the S2 bar. Same thing with the side/wings. They have slightly different 'clips' but can be made to work. The center headlight brackets however, cannot. This is also where the GTR differs, which has a different center bar, and different headlight supports (to either GTT system), it also has different 'wing' headlight supports which is what I am calling under the headlight. However those CAN be made to work with the GTT Reo for a GTR front bar by a small spacer and a drill/tapping a thread into the reo because the bolt positions are slightly different. So people only really need the center brackets to go between GTT S1, GTT S2, and GTR if you are happy to do some tinkering.
    • Indeed  😃  Appears the site is back up now (migrated not updated) - kudos @funkymonkey & @PranK
    • If this, then this You can't really get away without it. There are hacks that you can do in Nistune, but things are much easier with the sensor than without it. If you're not planning to Nistune the ECU, then stop right now and add it to your plan anyway, because the ECU is going to shit the bed over the missing ABS and TC computers that it expects to see, and you need Nistune to stop it chucking all its toys over the side of the crib.
    • hey guys, so ive done a complete +t conversion using mostly stock parts on my rb20de neo r34.  Im wanting to know if a boost pressure sensor is needed? Seems like the engine cuts out when i try to do a pull and I have a feeling its because a boost pressure sensor is missing. I'm using a stock r34 rb25det neo ecu.
