Yeah, both front and rear uni's look to be beefier than the ones on the 33 tail shaft. Rear one is rebuildable, front one isn't.
If you think 575 was pricey, I was quoted up to $1200 from other places.
I have a 33 speedo drive which i have adapted to the back of a 32 speedo face, in the process of jury rigging it atm to see if i can get it working before hacking up the back of the dash. If i cant get it, then the navara drive goes in. Only concern then is physically fitting the cable up to the drive as there isn't much space in there.
  • Replies 188
Posted Images
$1200!!! Made of carbon and balanced to 400kmh??? Far out some people think they can have a lend.
I guess mine did have problems at first, and in the end they had to pay to put the better unis on not me, which I would have had no problems paying in the first place, but as they say thats the way the cock flops.
Well after a week of mucking around with the r33 cluster and then an s13 one just in case the 33 one was cactus i grabbed a 32gtr drive (thanks risking) and used that.
The shaft is about 10mm shorter than the VL/navara unit so that you get away without removing the key way. and the bottom section of the gear is a nice interference fit over the splines requiring the bench vice to press the gear on. I just chucked a bit of loctite on the splines before installing.
I found that i also had to cut a new slot but only about 120 degrees around, rather than 180 as booster suggested.
Also bashed the bottom edge of the tunnel a bit to give a straighter shot at the drive for the cable.
Has anyone had cable failures due to the tight bends? or has anyone gotten a replacement shorter cable to suit the different drive position?
Edited by BHDave
How much would a mechanic charge to fit a r33 gearbox into a r32?
Thanks
Well, my total conversion cost about $3400... But that included the box and a jim berry clutch, and the one peice tailshaft, not that that cost much more than getting the standard one modded.
So say minus $1400 for the box $1200 for the clutch, mine cost $800 or so, inc the tailshaft, and a few misc bits. But thats also removing the existing box, and he had never done the conversion on a cefiro, so there was a little experimentation time.
  • 2 months later...
i went to nissan today they dont make the r33 speedo cog anymore, or the whole drive!!! and they dont make the navara pinion assembly with the 21 tooth cog..
does any1 have a spare r33 pinion assembly? or are any others the same? i only want the cog off it!!
my tailshaft only costed me $100 i used my r32 tailshaft and just put the yoke off the r33 tailshaft on it..
Tried it, couldn't find the info on how it's wired, wasn't lucky enough to guess it.
r33 speedo has 4 contacts on the back, one positive, one neg, and what i think is a signal in and a signal out. The speed sensor is a hall effect from memory which means both wires will give a signal, provided the other one is earthed. So through educated guess you can figure what has to go to the dash. Without tracing wires through an r33 you don't know what has to happen in between, which was the point i decided it was all too hard.
The dash requires butchering to fit the 33 speedo mechanism. it's a harder job than chopping off a cog and sticking a the 25 one on there
  • 1 month later...
So to round up the three pages what steps or items are needed to do this conversion?
Longer size bell hosing bolts, what sizes?
Tail shaft with R33 yoke, whats best or cheapest, custom one peice or mod the stock R32 one?
Cluch slave. Does anything need to be done to the bearing, housing or clutch fork?
Without going into debate, is there one setup for the speedo drive that has worked without trouble?
A custom cross member, anyone have a pic of theirs?
Slight change of trans tunnel shape, pics?
thanks
Daniel
(starting to sound like its gonna take me more than a morning to do this)
Edited by =premo=
I found a place in NZ who does a replacement part to convert the r33 box speedo to suit r32
I spoke to him today and mentioned Navara parts and he said he didnt use them yet mentioned it was genuine nissan and they had never had problems.
75 NZD and www.dodsonmotorsport.com
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
