that slot car may be of some value someday...
or not.
Lol I have it... and another one... cept it says AFX.. But.. lol I coloured in the brock one black... :happy: Might have to whip out the metho me thinks.
1,000.000 were made so every-one with a GTR32 with MOBIL 05 on the side.
Give it to a kid on the street so at least it was worth something to some one.
OR JUST , ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, :/ GET OVER IT :rofl:
i thought brock drove a 32 gtr back in the day against the v8 super cars and they baned the gtrs from series ... just what ive been told by some pretty knowalgeable people
Cant be to Knowledgeable, as it was Jim richards and Mark Skaife you are refering to in the GTR :(
lol. let's say it again. Peter Brock NEVER raced a GTR in the ATCC. I'll happily wager $100 on that fact against your knowledgeble friends.
Make your own decision's
I think i agree with nismo racer
i had this same slot car when i was a kid it was part of a ford v holden bathurst track ,the holden was a GTR and the ford wasn`t a falcon as well , the first thing i done was paint the GTR in the gibson motorsport colours
  • 8 years later...
Does anyone have any photos of peter brocks r32 gtr at all?
I have a slot car set from when i was a kid and one of the shells is an r32 skyline gtr with mobil stickers and peter brocks name on it? ive looked on the net and cant find anything.
He didn't race the 32 but he did modify them after he split with Holden like he did with some fords and BMWs
He didn't race any that I know of but he did modify street 32s as well as some ford falcons and BMWs this was after his split with Holden I hope this helps I found this in his autobiography
And at the moment I'm doing a Torana Lj with a RB2.6 and love the fan boys callin me out on the wrong GTR badge ;)
Yep jim and Mark raced and crashed out the gtr at Bathurst brock took the win in the VL but the race was called early witch gave the win to the gtr two laps b4 that's why the crowed went nuts booing and peggin beer cans. Jim and Mark got on the stage to collect 1st and jim called the crowed a pack of arse holes. To be honest Brock should have got the win
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
