  • Replies 115
Sabotage - Beastie Boys!
Yep, I'll go with that (or pretty much anything else other than "fight for your right (to party)" from the B Boys.
also that low rider song out of gone in 60seconds if funky
Low Rider by War, it's on the "A Nights Tale" soundtrack, I was also featured in "Video Daze" by Blind Skateboards, the first video that Jason Lee from "My name is Earl" is featured in.
Had a bit of a look around the old CD collection on the way home last night and can narrow the previous album choice down to Offspring - 'Bad Habit'
However I should also add Rammstein - 'Benzin' as a great driving song and if you ever get to Germany you have to listen to Kraftwerk - 'Autobahn' ;-)
F*cking Magnetic Fields...
Magnetic Fields is awesome music for hard corey driving. Ask Alan about the run through the spur in the rain listening to them!
A perfect song for losing your license to is definitely:
Bitching Camaro - The Dead Milkmen
"Bitching Camaro
Bitching Camaro
I ran over my neighbour
Bitching Camaro
Bitching Camaro
Now I'm in all the papers"
http://www.youtube.com/watch?v=vXE-uHGNk3k...ted&search=
Dj Tiesto - Adagio for strings remix
Anything by, Hilltop Hoods, Funkoars, Pegz and the Herd for the aussie hip hop lovers!
and for some reason the other day, when queens bohemium rhapsoday came on, at the guitar riff, i thrashed my car, lol. twas wierd.
Does everyone pretend they are starring in Waynes World when that comes on in the car???
Lol I can't believe someone hasn't posted this one.....
Chained to the Wheel.....Black Sorrows ;):)
...but seriously Money for Nothing by Dire Straits always made my right foot feel heavier for some reason :)
As Juzz said Prodigy - Voodoo People.
Other favs (even though I'm allowed 1). Of course this all depends on what kind of driving it is.
Prodigy - Serial Thriller
GnR - Nightrain, Coma, Right Next Door to Hell,
RATM - Bombtrack, Take the Power Back, Renegades of Funk
Pearl Jam - State of Love and Trust
Kernkraft - Zombie Nation
DJ Dean - Ballination
Warren G - Regulate
Nena - 99 Luftballons
Aha - Take on Me
Nik Kershaw - The Riddle
So many more, but that's enough for the timebeing.
Nena - A-ha - another child of the 80's :)
PS If you like german eighties driving music - you should look for 'Ich will Spass' by Markus
Warren G - Regulate
Aha - Take on Me
What about Back in Black - AC-DC..... i still remember watching a H-Street Video wiht that as the start music :(
Mario Rubalcaba - He isn't on H-Street, but this isn't the H-Street video either. Skating the "love tunnel" H-Street "Bootleg"
I bought "back in Black" for that song. :)
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
