  • 1 month later...
ok, i'll add mine here,(also on r31skylineclub list)
YEAR - 1984
MODEL - HR30 L20eT
BODY - sedan
COLOUR - dark blue metallic
YEAR - 1988
MODEL - HR31 gts rb20t
BODY - coupe
COLOUR - GMG
YEAR - 1982
MODEL - MR30 sedan L24 on LPG (daily)
BODY - sedan
COLOUR - white, will be for sale soon....will update when/if sold.
or look at pics here.. http://forum.r31skylineclub.com/index.php/topic,79509.0.html sorry, you have to be a member to see it!
:D
Edited by dodgsun
  • 2 months later...
YEAR: 1989
MODEL: r31 Ex Vic cop car [undercover gts2]
BODY TYPE: Sedan
COLOUR: white
1989 R31 Cop cars were undercover GTS 1's in a series 3 body, not 2's.
1990 Cop cars were undercover GTS 2's
20 1989 cop cars and 6 1990 cop cars.
Edited by cazz
YEAR: 1973
MODEL: KHGC110 (blown L28 power)
BODY TYPE: 2dr Hardtop
COLOUR: Yellow
Yeah, I know - strictly speaking it's not a Skyline, it's a 240K GT
Update - the blown L28 has gone to Nissan heaven.
Now replaced with L28 on LPG with twin Gas Research Australia gas carbies.
At least this one still has a crankshaft and rods inside a block that isn't ventilated!
1986 HR31 GTS 2 door
RB20DET NICS
5 Speed
MODS:
RB25 Turbo
Trust FMIC
Custom Air box
3" Zorst JunBL muffler
KYB dampners
Super low progressive rate springs
Adjustable front sway bar / Solid rear sway bar
Full polyurethane Bush Kit
Adjustable castor rods
Strut bracing
  • 3 weeks later...
thought id post my old cars up in here lol.
YEAR: 1988
MODEL: s3 R31 Skyline GX
BODY TYPE: Sedan
COLOUR: White
MODS:
RB30E+t
t3/t4 turbo
ka24 tb
vlt injectors
3" zorst no mufflers
pod
fmic
GTR fuel pump
koni rears, kyb fronts
z31 front brakes
s13 lca's
short shifter
locked diff
and some other small stuff.
http://i64.photobucket.com/albums/h191/OUTATIME_1/car1-1.jpg
http://i64.photobucket.com/albums/h191/OUTATIME_1/engine.jpg
thats b4 a tree jumped out in front of me in the hills 1 night.
http://i64.photobucket.com/albums/h191/OUT...E_1/repair9.jpg
currently gettin it back 2 stock for those great blokes down at regency.
YEAR: 1982
MODEL: DR/MR30? Skyline
BODY TYPE: Sedan
COLOUR: Silver
MODS:
rebuilt e88 head
kyb rear shocks & king springs
pod & cai
bought it as a daily while i get the 31 bak on the road.
taking me longer then planned 2 fix it up but yea all going now.
weird part is looks like a dr shell but with L series running gear. been told some1 probs
flogged the fj gear out and put in2 a better shell?
when pulled the head off bottom end looked brand new after 5sec clean.
http://i64.photobucket.com/albums/h191/OUT...E_1/piston1.jpg
http://i64.photobucket.com/albums/h191/OUT...E_1/carpic1.jpg
http://i64.photobucket.com/albums/h191/OUT.../enginebay1.jpg
http://i64.photobucket.com/albums/h191/OUTATIME_1/mr3.jpg
cheers...
Edited by OUTATIME
YEAR:1990
MODEL:R31 Series 3 GXE
BODY TYPE:Sedan
COLOUR:Platinum Glow
MODS:
Manual LSD
Lowered and Stiffened Suspension
2" extractors into 2" exhaust
16" Auscar Wheels wrapped in Potenza G3's
Autotechnica Wheel
Plus unknown internal work
ive already posted but i aquired another c210 and my old one died so i thought i better update here.
Old Skyline: august 1978 Datsun C210 (Dead) 280z motor and gearbox AGH-082
New Skyline: june 1978 Datsun C210 (Awesome) standard Motor etc PFA-123
Don't suppose you've got one to sell .Does'nt need to have a motor,or maybe you know someone wanting to sell. Ricky , [email protected]
im keeping that one for spare parts but if i come across any ill let you know..
The car is an original 1982 Nissan DR30 Skyline RS, imported into Australia about 5 years ago. The previous owner had plans of using it as a rally car, but ran out of time/money/patience and never finished the project.
I purchased it in early 2005. It had a cage, and the original normally-aspirated FJ20E, but that was about it. Everything else was standard. In fact, it wasn't even standard - someone had already pinched the DR30 brakes and factory LSD! Anyway, over the course of the next (last) couple of years, I have rebuilt or replaced almost every single piece on the car - some a few times!
This is as it sits now:
Body: Factory DR30 4 door shell, some (very little) stitching. CAMS Log Booked. Single roof vent. Painted in replica Peter Jackson colours, similar to George Fury's (and Glen Seton's) DR30 Skylines from the Australian Touring Car Championship back in 1986.
Interior: 14 point roll cage, CAMS ROPS certified. Sparco race seats. 3 inch harnesses. Momo steering wheel. Terratrip rally computer. Terraphone Pro intercom system. Battery located behind passenger seat.
Engine: I have 2 engines for the car at the moment.
#1: FJ20ET, rebuilt 3 months (2 events) ago. Factory 8.5:1 pistons. Standard T3 0.63 A/R turbo. 500cc Bosch injectors. 14 psi boost. 600 x 300 intercooler. Winged sump.
#2: FJ20E, rebuilt 1 month (1 event) ago. Factory 9.5:1 pistons. Factory everything, in fact. Winged sump. (Quad 45mm throttle bodies and headers yet to be installed)
Engine Management: Megasquirt 'n' Spark ECU. FJ20 distributor handles the crank angle duties. Bosch 124 ignitor. Bosch MEC coil.
Exhaust: 3 inch -> 2.5 inch exhaust. 1 muffler at rear. (1 hot dog at front when normally-aspirated)
Fuel Pump: Bosch 968 pump.
Clutch: 240mm 5 puck sprung centre Exedy clutch on FJ20ET flywheel.
Gearbox: FJ20 gearbox casing, machined to accept RB20 internals. 3 piece synchros on 2nd and 3rd. All new bearings and synchros 3 months (3 events) ago. Standard ratios (for the moment).
Diff: R200, 4.625 ratio (4.375 and 3.9 ratio options). KAAZ 16-plate limited slip centre. Rebuilt R200 halfshafts.
Front Suspension: Custom struts based on DR30 units. 40mm Commodore Bilstein inserts, rebuilt and revalved by Heasmans 1 event ago. 200 lb/in King springs on adjustable spring platforms. Custom adjustable strut tops. Modified radius rods. +6 degrees of caster, -2 degrees camber.
Rear Suspension: Bilstein 46mm shocks, rebuilt and revalved by Heasmans 1 event ago. Adjustable platforms. 175 lb/in King Springs. Plated and gusseted trailing arms. Plated rear crossmember.
Brakes: 1 inch Patrol Master Cylinder on small can Datsun 180B booster. Lines through cabin. Rear pressure limiting valve (driver adjustable). Hydraulic handbrake adapted to factory ratchet.
Nissan Stagea 2 piston sliding calipers on 280mm x 30mm ventilated discs on the front. GavSport pads. VT Commodore rear calipers on 295mm x 18mm ventilated discs at the rear. Lucas pads.
Wheels: 15" R30 Skyline Ti wheels (17 of them), 15" DR30 Skyline RS Wheels (4 of them).
Tyres: Whatever I can lay my hands on! Generally 205/65-15 Dunlop or MRF rubber. Fronts last about 6 months, rears (depending on compound) last about 50 km competitive!
I am sure that there is more that I could tell you about, but I can't think of it at the moment.
Hey, Matty.
What was the reason for going to the stagea calipers and bigger discs? did the standard DR30 gear suck that badly, or was it just marginal with your power output? I'm considering a stud pattern change to the RX (to suit a proposed S3 rear end) and have access to a pair of DR30 front struts pretty cheap. If the brakes are pretty ordinary (running about 140RWHP atm) then might reconsider whether there's any benefit (running Volvo 4 spots at the front and they work ok)
Also, to fit the Bilsteins, I assume you have grafted new tubes tot he struts. Did you use the Commodore tubes, or have you used something custom? I gather the coilover hardware is bigger than the 2" sleeves that go over Datsun struts.
Cheers
    • If we're going after market gauges, I'm a big fan of Australian made... Get some RedArc!
    • Unless you're fortunate enough to buy a newer car, getting an older style plate to match your name/car is difficult because they've already been purchased.  Unlike other countries, personalised plates are locked to the country and not region, so there can't be multiple versions of the same plate but with a different area code.  Hope that helps
    • People use the numbers to make it look like letters to spell words/names, which is where the illegal spacing comes in. For example this GR Yaris
    • Today's rock removal from my stock pile out the back into a 4m³ skip bin, I still have a bit to go, hopefully there's enough room in the skip bin, it will be close My daughter and her boy was coming on Sunday to help, but, I got possessed by demons and started work as soon as the bin arrived at 1230 today Lots and lots of barrow loads were achieved  Currently I'm sitting on the lounge drinking beer thinking of how I should have waited till Sunday for some help, tomorrow will be a day off, in saying this, my day off will involve prep and paint of my alloy coolant and PS tanks with wrinkle paint (Jackie is in Sydney till Sunday so the home oven will get a run curing the paint....LOL)
    • That's why I said it is a meaningless term. Because there is more than one meaning that people can apply to it. When we said "highflow", that is exactly what we mean, and exactly what is done. In a highflow, they take your housing and machine them out to take bigger wheels, have a better internal profile, etc etc, and fit a new core with the different/better/bigger wheels.
