Hey Guys.
Since getting my 32 GTS-4 4 Door, i cant seem to find many others.
I Know there are quite a few
4 Door GTS-T's
2 Door GTS-4's
I really havent seen many 4 Door GTS-4's.
Who on here has one??????
I Know they were the rarest of the R32's (Fewer Of them Than GTR's?) but im unsure how many landed here
https://www.sau.com.au/forums/topic/138668-who-has-an-r32-gts-4-4-door/
Ash I have one, here in Tassie... It's a 5spd too. I know of two others here in tassie, one of which i think is an auto however...
I dont like the sound of the auto 4WD gearbox *shudders*
Does yours have the boot badges?? The sedans have badges, the coupes have decals. Copies of the decals from a coupe would be ok if I cant find the sedan gts-4 badges :O
Don't have one.. But this I would say is the fastest in Aus.. Bit off topic but yeah
http://www.imports101.com.au/view.php?car=1580
FARK YEAH, that thing is awesome.
Yeah, The nissan and GTS4 ones are fine. but the Skyline one in the midle seems to be "pitting" and decaying sort of *shrugs*. probably just rip that one off and make something up for it myself.
Hey champ yeah ive gotta R32 GTS-T 4door RB2.4L!!!! something different she goes!!!
got any pics of yours?
Hey Guys.
4 Door GTS-T's
2 Door GTS-4's
I've got a 2 door GTS4... when looking for one in japan last year (I specifically wanted a GTS4) I found that the coupe's were rarer than the 4 doors as the sedans were sold and bought in large quantities by families living in snowy regions (where you'd need AWD). I wouldn't consider them rare by a long shot. The 4 door Autech GT-B's which were based on a 4 door GTS4 chassis on the other hand is a rare find.
That said 9 out of 10 of GTS4s I found had pretty bad rust due to salt on roads n snow sitting between panels... So chances are most of the GTS4's (esp 4 doors) won't be eligible to come into Australia.... so no threat of em becoming common.
I ended up finding a GTS4 owned by a dude in tokyo that hadn't been used in the snow and was pretty happy with its condition.
im trying to find the stats for production i had of them.
but there were less 4 door GTS-4's made than any of the others.
they were the most expensive from new aswell, behind the gtr of course.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
