Hey guysmoved to mackay 3 yrs ago bought a r32 gtst with a blown motor. Replaced motor but got mega issues. In the deep end for sure now but love the car cant wait to drive it when its going
Hey mate, welcome.
If you need any information, most people following this thread are very knowledgeable.
  • Like 1
Hey guys I have a problem. Replaced a blown rb20det with another. The new motor arrived with the timing out by 4 teeth. We re did the timing and got it running. But it is idleling rough as guts and the motor will die without throttle. If I give the throttle a tap it jumps up but then will go out of control. Up to 3 Grand then slowly comes back down. I have checked afm iac and cold start valve by unplugging them to see if I get a response. Which I do. I have power and signal going to all injectors and coil packs. All cylinders fire. The ecu has a ewad out of 55 which is no faults. Im out of ideas. Will do a boost leak test tomorrow with soapy water. SO CHEAP! Thanks in advance guys
Hey mate, seems like you have most of the bases covered. Usually the best way to test for leaks is to pressurise the intake.
If you are handy with a welder, weld a compressor fitting onto a piece of pipe with a tap, and weld the end shut. Them simply remove your AFM and clamp it there and slowly crank the pressure up to 30psi.
It is by far the only accurate way to find leaks.
Hey guys did a pressure test on the intake and I have a blown plenum gasket  the supplier I bought it off has a start up warranty on the motor the fact that this was already present has asked for a quote to fix and get the motor running. Lesson: warranty is awesome
looks like ur lucky there mate
After a new clutch cylinder for my car. (P/N: 30620-21U23)
Going to try Brakemart, Repco and Bursons, but just putting this up in case these fail and anyone has one lying around
Its a 3/4 Nabco slave, believe they might be the same as R32 ones, but not 100% sure
Hopefully should be able to source a new one anyway
Really? I dont go there that often. And I always forget to use my racq card anyway lol.
Ended up getting my slave honed and re-sealed by Better Brakes. They had it done in about an hour as well. Looks all shiny and new now :)
Works as well which is a plus
They were originally going to re-sleeve as well but said the bore didnt end up being that bad.
was just shy of $50, noone seemed to stock a new one. Was about to try nissan but dare say it would have been $100 plus
I don't think a re-sleeve would have cost much more, said it was going to be stainless re-sleeve so should last longer, but I'm happy as with the result. Like I said, looks like a brand new one after they sand blasted and re-kitted it
Have a funny feeling it might drive again tomorrow :)
I quite like 34's in yellow
get the wallet out Sean and just do it :P
Get the impression that this is really well looked after as well, has only been lightly modded. Would be a good one
Edited by 89CAL
If you're buying a BNR34 fro Qld, let me know. I know a few of the Brisbane bmr34 guys and they can give me the down low on the car. :)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
