  • 5 months later...
  • 2 months later...
sorry about the pictures guys, it was deleted from the server when i didn't renew the subscription.... ill have to dig up my photo archives to see if i have back up.
And i have been M.I.A from this forums for a while
  • Like 2
  • 2 years later...
  • 1 month later...
  • 9 months later...
On 10/23/2006 at 5:16 AM, E_Lu-SHuN said:
You will need these when you get the gearbox ( These are all r33 parts except the gear knob )
(Circlip is in place to hold the gear stick in )
(had to cut peices off so it would go into gear)
( still using the auto surround for now until i find a r34 manual one )
Here is the wiring for the inhibitor and reverse switch. I didnt connect the neutural switch.
that is the connector from the car the wires to work with are the RED(REVERSE), BLACK with PINK(INHIBITOR), and Grey(POWER)
Anyways here is the allocating pins from the auto gearbox
And here is a rough diagram of how to connect it to the manual gearbox. Colour coded
**both brown wires are the same.Doesnt matter which brown goes to what..its the same**
The reverse switch consists of two brown wires(as seen in diagram) . One brown wire from the reverse switch joins together with the inhibitor(BLACK with Pink) and the power(GREY).
The REVERSE wire (red wire from the auto plug) connects onto the remaining brown wire of the reverse switch.
So for the reverse switch, one brown wire connects to the reverse signal(red wire) and the other brown wire joins with the inhibitor and power(3 joint wires).
Hope that is explaining it easy.
The auto ECU will work fine with the gearbox. You will geet a A/T light up on your cluster, but dont worry nothing is wrong.
Hope my tutorial is helpful for all you r34 tiptronic owners wanting to do a conversion with r33 gtst parts.
Glad to help others.
cheers,
Sorry to bump and old thread. Does anyone have the wiring diagram or pictures for this at all please? I'm struggling with what goes where. Thank you in advance!
  • 10 months later...
20 minutes ago, toranarod said:
If I was buying a R34 How can I tell if it was originally a Manual or an automatic. is there a number on the Id plate that would specify what the car was when it was manufactured
Yes. The Id plate tells you what transmission
The original Nissan Motor Co., LTD. Japan plate has the type of transmission the car was born with, stamped at the bottom next to "Trans".
If it is/was an automatic, the stamping will read: RE4****. See attached as an example.
If it is a manual, the stamping will read: FS5W****.
"*" = the star won't actually be stamped, but different models have different suffix after the letters/numbers of what I've posted.
thanks that is very help full.
Is the car devalued if it was once a Auto and now a manual?   I have found a coupe GTV R34 For 9k is that a reasonable price for a no original car.
Not a worry mate.
In my opinion, the value stays the same if not increases it as it's a far better car to drive, now it is a manual. Best to always get it checked by a professional that the conversion was done correctly if you can't spot stuff like, dodgy wiring, hacked firewall for the clutch master cyl etc, yourself.
The auto's aren't a bad thing, they're very reliable, but they're not great for nearly all things that involve spirited driving. ?
  • 1 month later...
On 10/22/2006 at 9:14 PM, E_Lu-SHuN said:
Once all that is done You can bring it to a mechanic, What you can realise now that the rest of the work, will be like a clutch change in a manual. Dont let them tell you otherwise. The spigot bush in the auto may be time consuming but it shouldnt take more then 20 min to take out. The wiring is easy if you follow my diagram so dont let them use that excuse to charge that extra $$$
Bleeding the clutch is easy.. extra charge?
changing gear oil is simple
No mods to the gearbox cross member was done. It fitted in EXACTLY
The tailshaft WILL bolt on.
Make sure you have all 9 bolts for the pressure plate to flywheel. If you dont have it then you might want to ask NISSAN for it.
You can remove the speed sensor on the autobox. The connector is next to the plenum. Just follow the wiring and unplug it
All up the conversion from the workshop cost $300 and under 5 hours. That was cheap considering i supplied EVERYTHING but just set the budget to $500 for the conversion, just in case.
Here are a series of pics during the conversion
( undoing the torque convertor 4 bolts)
(Auto GB flywheel)
(We had to cut the spigot bush because greasing it was not working NOTE: Rear main seal was still fine)
( auto box out)
(manual flywheel bolted on. ALL bolts tightened to correct torque settings)
(bearing getting replaced)
(starting from left to right, reverse switch, Neutural Switch, and speedo signal)
(scattered bolts for bellhousing and pressure plate)
( manual gearbox bolts on with the original holes for the gearbox cross member)
How do I view images ?
  • 4 months later...
  • 4 weeks later...
  • 4 months later...
Hey guys, didn't was to start a new thread as it would be excellent to have this information on this one for future and current users.
I'm converting my 2001 R34 Gtt Sedan with a 1995 R33 Gtst Gearbox and all parts from that car.
I've been given a wiring loom and I know which cables go to the transmission as they are obvious and I have plugged in on one of the photos.
I'm not sure about any of the other plugs though, I have yet to pull the dash off and connect the break pedal and clutch pedal.
Are all these plugs something I will figure out quite easily when everything is pulled apart or is going in blind a bad idea, do I even need to use half the plugs on the loom?
Thanks guys and Happy New Year
  • 5 months later...
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
