I know that this post could cop a fair bit of flamming etc etc, but I was just curious the other day, what kind of costs/things would be involved in Turbo charging a commodore say a VS,VT or VX?
Obviously Turbo charger, and a tune etc etc
but what kind of costs are we looking at?
https://www.sau.com.au/forums/topic/140569-turbo-charging-a-commodore/
  • Replies 74
Let me be the first to say :):)
Since the V engines you either looking at twins or one complex bitch of a manifold. Then you have issues with the stock compression and engine management. There was some kind of commy wagon with a turbo at the last dyno day I was at that pulled 195rwkW with over 200k's on the engine.
I'd say your better off selling and buying a V8 or maybe getting an XR6T if your into the aussie turbo. A v8 will definately sound better. Your not going to get a good answer on here, definately try a holden/commodore forum.
The compression in the engine is to high and you will need to deal with this first.
Then you need some savvy and choose a turbo that compliments the motor.
Get some custom work on inlet,manifold,exhaust and intercooler mountings.
You will need to re-tune your car and set up a boost controller.
After you have spend 1000+hours and $7000 and the thing is not working right
because you nhave other problems...ie fuel pump or injectors or mis-firing etc etc etc.
It would have been better off buying a gtr32 for $20000.
Hope I have been of some help. :):)
You are better off super-charging this gives you good gains and can bolt up to your set-up .
my mate single turboed his vr commodore, had the turbo at the front of the motor which melted the clutch fan then about a month later blew the motor, was only running 11psi but was pulling a nice 225rwkw's!
The thing pulled like crazy while it lasted.
Unless your going to rebuild the motor don't bother!
i think with a small budget you can bolt on a smallish turbocharger and get some good gains but the issue with the v manifold is a big problem
so you would have to go small twins. as long as you dont want captain insano power it should be reasonable ish, but it will all be custom, which is where the costs add up, i dont think there would be many off the shelf kits
V6 commodores - they have the worst engine I have ever worked on. Absolute rubbish - nothing like an rb.
Totally agree, I use to own a shit box commodore, biggest load of shit....
I don't think I've ever seen such a bad collection of bad ideas put together in the v6's. From balance shafts, super long timing chains to pissweak conrods and water pump bolts that go through to the water jacket - they are a pitiful excuse for an engine. Pushrods??? They were supposed to go with the red motors and dinosaurs.
Edited by gtst25
http://www.ls1turbo.com.au/ttspecs.htm
http://www.otomoto.com.au/kkrturbo.htm
i would hardly say it works out crap...
sometimes people on here are quick to diss anything which isnt a skyline.. which is pretty funny when a lot of people are driving stockish 33's
Let me be the first to say :P:rolleyes:
I've seen that car, he came to my work and bought some parts. I saw the sticker on his windshield saying "Ovaboost" and I was thinking wtf its a commonwhore.. Then he popped the bonnet and theres a turbo bigger than my head strapped to the side of it :) . He reckons when he got it done the standard auto lasted as far as him driving away from the workshop and planting it for the first time ahaha.
Car looked like a bit of a POS though, but a V6 wagon that runs 12s is a pretty impressive achievement
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
