  • Replies 54
are u sure the v power is the new "optimax extreme" ?
i always thought the v power stuff was red at the bowser and is the replacement for normal optimax and that optimax extreme was still called that and avaiable
V-power racing is the new extreme
V-power is the new optimax
Personally I wouldn't be running it in my highly tuned import without a proper tune for it or had it checked on the dyno, but hey, to each their own :P
Ziad - what do you get to a tank?
I'm sitting just below 1/2 with about 280km on the trip meter.
Will run it in the car at Wakefield next week too - see how it goes.
james, i dont know, as the car is at panel beaters hence the half tank. the tank\guage is not even, it will generally go slowly but after it reaches half it drops down quickly. on normal optimax i was getting about 13l\100k on general driving with a few squirts. u must be really babying it or a lot of freeway. i got about 8-9l\100km on my trip from sydney.
pretty sure its normal for petrol gauges to fall slowly at first, then quicker later on into the tank...
something about the way the sender works I believe :)
mine works the opposite way :)
people should just get the brochure on the new v-power fuel, it says that there is a new friction modifier added and thats it....IMO still a marketing exercise :)
The V-Power branding has been about for ages O/S...i doubt there is much new about it although they reckon it is...as it happens I had the 100RON in today when it was tuned...seems to go ok..my clutch doesnt though.
Just telll the service station guy you need an MSDS so that you can carry a jerry can in a work vehicle. Clever trick for wehn ppl dont want to tell you whats in their product :laugh:
as if the poor (insert indian/pakistani) console operator knows what a MSDS would be ;-), esp in independent servo
mine works the opposite way :O
I'll see if I can get an electronic copy of the MSDS for the fuels, as they have the breakdowns of what compounds are used in them.
Agree that it's a marketing exercise. Disagree that we should read brochures - that's the marketing...
I would like to find out what the MSDS says and what some car tuners think from tuning experience
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
