  • Replies 54
are u sure the v power is the new "optimax extreme" ?
i always thought the v power stuff was red at the bowser and is the replacement for normal optimax and that optimax extreme was still called that and avaiable
V-power racing is the new extreme
V-power is the new optimax
Personally I wouldn't be running it in my highly tuned import without a proper tune for it or had it checked on the dyno, but hey, to each their own :P
Ziad - what do you get to a tank?
I'm sitting just below 1/2 with about 280km on the trip meter.
Will run it in the car at Wakefield next week too - see how it goes.
james, i dont know, as the car is at panel beaters hence the half tank. the tank\guage is not even, it will generally go slowly but after it reaches half it drops down quickly. on normal optimax i was getting about 13l\100k on general driving with a few squirts. u must be really babying it or a lot of freeway. i got about 8-9l\100km on my trip from sydney.
pretty sure its normal for petrol gauges to fall slowly at first, then quicker later on into the tank...
something about the way the sender works I believe :)
mine works the opposite way :)
people should just get the brochure on the new v-power fuel, it says that there is a new friction modifier added and thats it....IMO still a marketing exercise :)
The V-Power branding has been about for ages O/S...i doubt there is much new about it although they reckon it is...as it happens I had the 100RON in today when it was tuned...seems to go ok..my clutch doesnt though.
Just telll the service station guy you need an MSDS so that you can carry a jerry can in a work vehicle. Clever trick for wehn ppl dont want to tell you whats in their product :laugh:
as if the poor (insert indian/pakistani) console operator knows what a MSDS would be ;-), esp in independent servo
mine works the opposite way :O
I'll see if I can get an electronic copy of the MSDS for the fuels, as they have the breakdowns of what compounds are used in them.
Agree that it's a marketing exercise. Disagree that we should read brochures - that's the marketing...
I would like to find out what the MSDS says and what some car tuners think from tuning experience
    • Sane enough. Remove the roof liner, because the acid will go everywhere.
    • Thanks guys, I really appreciate the help and experienced opinions.  I have spent a lot of my life working on boats so I'm pretty good with fibreglass. I'll take everybody's advice in here;  I'll cut a little more of the 2nd layer away as it's a bit crunchy rust and also it's sitting high now. Then I'll wire brush it all a bit to get off anything loose, then I'll soak the bejesus out of it all in rust converter. I'll make sure to get a little hose piece and feed it into all the holes and gaps between the roof layers. Then I'll fibreglass up the holes.  Then I'll get a pallet of filler and mix it with 3 buckets of hardener and hope that is enough to build up the roof corner.  Does that sound sane? Is one type of filler better than others for this?
    • My goals for it atm are to get it registered, respray and some mild power gains eventually... I picked up the car from an elderly gentleman near the border of NSW and VIC, its honestly a bit rough and looks like its been driven on a farm (because there was so much dirt underneath). Last week I dropped the subframe and emptied the old fuel out + added a new fuel pump (think the old one went bad from old fuel). Now I'm onto fixing a coolant leak at the rear of the engine + adding a new radiator as the old one is corroded. After that i have a new bumper, coils (as the old were leaking) and lots more
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
