  • Replies 62
My top grade rims *cough were manufactured by Rossa.
Never herd of them my self.
As I said in my post, I wanted to change all four rims to stockies but could'nt remove the front two. Still wouldn't have expected what happend to happen, but can't cry over spilt milk as they say....
I reckon I went around that track 20 times and grinned like a little boy on Cristmas eve on every one of them. Just loved it.
Good fun isn't it? :blink:
:yucky: man thats gotta hurt.. who woulda expect that to happen? good that ur all good though. ill show this to my mates and then maybe they will stop telling me that im wasting my money buying expensive rims like volks or somethin. cant wait to get my car on the track!
There are lots of wheels that are made by other lesser known companies - does this mean that these wheels are not as good as ones made by enkei or volk?
generally i'd have to say yes. Enkei/Volk etc are going to make better rims than what you find at bob jane or the tyre factory etc
Lesser known is a bit broad, as just because you haven't heard of them before doesn't mean they're a shitty brand.
Price will usually tell you, as well as whether they are a forged rim etc. Generally these 17 inch rims from Tempe Tyres etc for $1000 with tyres aren't going to be the most shlt hot rims around... you get what you pay for
Forged are good, but there is nothing wrong with cast wheels. Nothing at all., Only they have to be good quality castings. Forged rims (depending on materials) can be nice and light, the flip side is they need all the strength they can get because they are light and can actually be so hard they are brittle...hence why race wheels are replaced so often. (Forged magnesium etc)
A thing to consider is what the weight bearing capacity is for the wheels. Some of the cheap ones shoudlnt be under 1400kg sports cars...
..anyway, thats my thoughts. I could be wrong!
That's pretty scary... I've got myself a set of rims which is sourced through local T-mart, lucky haven't gotten anything similar but haven't got a prob last yr @ winton & calder... but looks like mine has a slightly bulkier design around the hub, so hopefully it's stronger. And last week I was considering to buy a Starcorp Racing wheel advertised on ebay since i've been looking for something wider than this 17x7.5" I have...
Or could it be that your rims (since it came with the car) might have developed stress/fatique fractures over the x years of use, cos you can't really tell how the previous owner treats their car...
Those rims are junk, but at least you knew that they could be a problem and tried to put stronger rims on. Unfortunately with a load rating that just won't accept racing loads you may have difficulty getting them to pay for damage, which is minimal and could have been far worse.
If you want to take it further and need some expert engineering advice contact me.
Welcome to the unique group with "Track Disease".
Hmm - i checked on www.tgsperformance.com.au - the rims I have (HR racing) is around the $1200 - $1400 range. Perhaps wheels like these are suited more for looks rather than for racing.
I run spacers and haven't had a problem thus far... but I'm a little paranoid too now! Still gonna use them though
yes but you have forged monoblock wheels Dane, I would say the LMGT-4's are more than a little stronger :)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
