  • Replies 147
Posted Images
^^ yep, those all have to be fuel resistant.
when i did the pump in the R31 I put some ordinary closed-cell foam in as a spacer, and the petrol destroyed it in very short order. if I was doing some custom work in the tank I would cut off small pieces of what i wanted to use and soak them in petrol for a week to make sure they didn't dissolve.
sweet setup though, well done B-man :ermm:
Did you have 1 or 2 Duncan ?
Fuel pressure is base - no aftermarket reg
Had to put a check valve on the line just out of the tank as the ones that are allegedly on the Walbros don't work very well - apparently this is common.
  • 2 months later...
So far so good with the Walbros - 45 PSI idle fuel pressure - goes up to 60 when boosting. Not a problem at all.
People seem to love them or hate them the Walbros - the Yankees love them - They flow well, draw less current, have a small form factor - thus in tank fittment of two is not a problem. And they are in-expensive compared to some others.
So - just an update on where I am at with the Cosmo now.
After sorting thru some small issues - Fitting a 4.5" exhaust, new mufflers, re-tune etc - am now at 340rwkw (that's with the auto so engine HP would be close to 400 or so. And that is running 10PSI
Boost starts at 2300RPM, 5PSI by 3000 and Full boost 4000RPM all the way to 8200RPM (nice power band from 4K to 8.2K) Power climbs and climps and is still climbing at redline.
Boost will be going up soon - to 15 PSI. (Need new 3 bar MAP sensor and complete retune - bugga) So hopefully over 400rwkw
I have a MV Stage II built box coming with a 3800 RPM stally.
10s here I come :P:D:)
I took the return fuel line off while on the dyno (Ok Ben at UAS did it but I watched :P) and at 255rwkw the flow completely stopped. Scary stuff. Also had major issues with fuel pressure which went away once I put an R34GTR pump in there.
As you say though, some love em and have no problems and some love em.
It's a MUST to run a dedicated relayed circuit from the Battery for these pumps. They don't voltage step well.
340rwkw - my 1600cc/min secondaries are running at 20% or something - no fuel problems for me
You also gotta ensure you get Genuine Walbros - there's China copies out there that are shite.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
