  • Replies 251
i'm looking at buying one of these
700177-5007
gt3076R
external gate
front trim 56, .60 ar front surge slotted
.84 rear trim, .82 4 bolt rear
i have the option of the .60 or .70 front
is tthere going to be much difference?
my combination at the moment is a standard rb25det
Ive got a 6boost and plazmaman
was recently making 300rwkw on a standard exhaust manifold. 3076R.70 front. .82 rear internal gated
i
everyone is ignoring my post =[
hey mate, you're wasting your time putting a 0.7 compressor cover on this type of GT3076. The 0.6 is surge slotted and flows more than enough for this compressors peak.
0.7 will just make it more laggy, and give you headroom that you can't access and that the compressor can't reach.
Bumping this great thread with my results that are finally here.
Despite what most people advised, i ended up buying a 3071 with the genuine Garrett .82 rear
I absolutely love it; full boost (17psi) by 3600rpm and makes 280rwkw. If i did get the 3076 i still think i'd struggle to make 300 with internal gate. (I firmly did not want to run ext gate)
it was awesome. I had a 0.82 rear on it and didn't like the lag.
Get the 0.63 rear with the slightly bigger internal gate on it, there is a special one you can get. Its still garret, you've just got to ask for it.
I Was running 14psi, 16psi, 18psi, and 20psi without issues, but I recommend water meth injection for 18psi+ on this rear. It helps with the detonation.
And f**k the response was good. with the WMI, I was lighting 1st, 2nd and 3rd, and fishtailing at 100\kmph when I knocked it back to third, and not even having to dump the clutch. Just rolling on the throttle gave it a kick in the ass.
Just make sure you have a good tuner, and good support systems.
Thing is I cbf changing my setup again.. i don't think my injectors or my bank account have much more to give sadly.
If i start to hunt more response down the track, perhaps i'll go the smaller rear. Good to hear that it can be done!
Nice Ric, intake held up. :thumbsup:
That 3071 is working hard, now dump some eflex in the tank for us... :yes:
Do you have a graph?
I'm seriously considering buying the GTX3071 with .82 garrett IW rear...
After seeing the negligable difference in response betwenn the GT3076 and GTX 3076 on that subie, i really hope the GTX3071 is the same with slightly more top end and negligable difference in response.
Dreams of this turbo running Eflex :D
  • 4 months later...
Does a GTX3076 spool slower compared to a Gt3076? Was the Gt3076 ball bearing?
  • 2 months later...
Thinking back I should have ordered the 0.63 A/R turbine housing on my 76R ad if I can I'll probably exchange it .
As Mr Mafia showed they make pretty good torque on an RB25 and seem to have really good response for a GT30 based IW turbocharger .
A .
  • 3 weeks later...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
