This was originally listed as an "End of Sale" notice but it appears Apexi are dropping some of the least popular models. There also appears to been some supply issues with some of the processor used in some of the models (NEC chip for the Skyline units)
After about 1 to 2 years of rumors that the PowerFC would be discontinued this time more rumours have surfaced.
The are more rumours found here on the rx7club. http://www.rx7club.com/showthread.php?t=596718
Some more discussion on the topic here on the gtrcanada club. http://forums.gtrcanada.com/viewtopic.php?t=11147
PowerFC AP Engineering versions - All models discontinued
PowerFC Pro versions - All models discontinued
# AE86 discontinued model
# BG5 discontinued model
# ECR33 discontinued model
# EG6 discontinued model
# EG9 discontinued model
# EK9 discontinued model
# EP82 discontinued model
# EP91 discontinued model
# ER34 discontinued model
# FC3S discontinued model
# GC8 discontinued model
# HCR32 discontinued model
# JZA70 discontinued model
# JZA80 discontinued model
# JZX90 discontinued model
# JZZ30 discontinued model
# RNN14 discontinued model
# ST205 discontinued model
# SW20 discontinued model
Some models have been discontinued as they weren't popular, some removed as the FCON dominated that model (toyota supra) and some were removed as they have run out of NEC processors (Skyline R33/R34). We are unsure at this stage if any more models will be cancelled or removed, or if its just a reshuffle of the crap models, and clear out some old unpopular models. AP Engineering no longer exists as a company, so the AP Eng versions have gone. There are of course many many units in the public market so there should be plently for sale second hand it just means these models aren't sold as new anymore.
We have no news of a replacement unit (if in fact one is coming??), specs, feautres, name etc so if you have any information on unit, or details please post them up
https://www.sau.com.au/forums/topic/143433-end-of-some-apexi-powerfc-models/
  • Replies 126
only thing remotely new from apexi's site is the PNBC
which is a piggyback system, its a bridge between SAFC and PFC
http://www.apexera.co.jp/carlife/pro_apexi...ics/P-NBC1.html
its a bit wierd, its like the emanage
There is a few ECU components that have been discontinued so this maybe the reason.Wolf V400 used some of these parts that are no longer avalible but the new stuff is light years ahead as used in the V500 so id say a new PFC will come out with the same new generation parts also.
Blitz...
Its the first I've noticed but the R33 and R34 PFC's are no longer available from Nengun with a in bold writing stating they are discontinued. The R32's aren't even listed any more.
So I'd say its definitely looking as if the pfc for the GTST at least has reached the end of the road.
Blitz...
Shit, I was on Nenguns site today and didnt notice.
BRB, buying bulk Power FC's :P
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
