  • Replies 160
Many thanks to all who voted for my car aswell, there was some stiff competition in all classes, was hard to vote with so many nice cars there....
ahahah damn you!!! and damn rush for voting for your car and not mine :laugh:
heheh, I think most of the cars i voted for won!!
ive only got myself to blame for not becoming a member and bringing my car along........
But i was there with my mates......we were the mountain bike bandits lol,
i was so jealous,the turnout was good the cars looked great..ill catch the next meet.
Thanks for the vote Natasha!!!!
Ferni - if you had headlights like mine you might have had a chance... :laugh:
Those headlights are in a league of their own, especially with the black track tape on, they look like sunglasses. Very cool car and got my vote (sorry other 33 GTR owners!). :ermm:
Those headlights are in a league of their own, especially with the black track tape on, they look like sunglasses. Very cool car and got my vote (sorry other 33 GTR owners!). :P
ahaha you do realise its a joke - i have the same headlights :laugh:
I did not rig the votes, I didn't even count them and i only voted once!
It was the peoples choice and they chose Lil Blu!! :(
Speaking of Simpsons: I Cho Cho Choose You!!
Haha I'm only shit stirring.
Clearly I'm jealous :woot:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
