well Super GT (GT 500 class) are claimed to be the quickest GT cars in the world... "The mines GTR" is based on a modified street car and retains rego and a majority of standard body parts. a GT car is a 100% race car. This years GT500 class NSX are running turbos now too...
https://www.sau.com.au/forums/topic/145815-mines-gtr/#findComment-2723730
yeah, understand that. Just didnt realise how quick they actually were. I mean the Mines GTR is no slouch, it's a fckn quick car, but damn, those gt500 cars are insane
https://www.sau.com.au/forums/topic/145815-mines-gtr/#findComment-2723739
Race spec brake pads sometimes squeal because of the composition of them..its normal
I'm not sure what you mean by race spec brake pads, but the pads i run and others i track day with don't squeal like that when under heavy braking, under light braking yeah for sure... but when stomping on the brakes you don't normally give them a chance to squeel... i'm probably wrong tho :thumbsup:
https://www.sau.com.au/forums/topic/145815-mines-gtr/#findComment-2724617
my carbon/ceramic composite pads squeal like a bitch, cold/hot hard track braking/soft street braking doesn't matter. it sounds like a train. :thumbsup:
other race type pads I have had didn't do it, but these particular ones do. when up to temp though they still pull up nicely.
https://www.sau.com.au/forums/topic/145815-mines-gtr/#findComment-2724673
NSX does quite well, but it also has 50kg extra ballast compared to the rest as it is an MR. This years NSXs went back to 3.5L NA engines instead of 3L twin turbos though, or maybe they changed during the year or something, eitherway, they are running the NA engine now instead of the turbo. Seems like an odd choice...
https://www.sau.com.au/forums/topic/145815-mines-gtr/#findComment-2726866
A video of a JGTC NSX vs a Road Car?
How about they compare the last JGTC GTR running a VQ VS the JGTC NSX?
I'd like to see some holden and ford V8 supercars there as well showing their weight transfer
on the corner s :(
That would be an interesting race...
https://www.sau.com.au/forums/topic/145815-mines-gtr/#findComment-2728691
The footage is of Hot Version International 01 DVD; SPECIAL RUN IN TSUKUBA for Keiichi ‘Drift King’ Tsuchiya bids farewell to his professional racing career. He was trying to set an all time lap record in his ARTA NSX GT500.
Edited by Forged
https://www.sau.com.au/forums/topic/145815-mines-gtr/#findComment-2728702
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
