uk front bar???
if your talking about the r33 then its just the vents that come with the nismo oil cooler
You get those "add on's" with the cooler kit? Its $2000. Bit steep for a cooler and a few bits of plastic. :(
i think he means coz it was standard on the uk delivered cars no?
Exactly.
Perfect fucntion yet looking standard. Uhuh!
yep, u need sum way of getting enough air to the oil cooler when its put behind the front bar.
You should know that when ever the word nismo is mentioned in the product that its not going to be cheap.
Im actually supprised that no one has made a replica copy of them as im sure there would be a market for them
I put my oil cooler on the drivers side front bar and just used border carbon ducts as they allow enough air with bigger openings.
If they did come standard on uk model cars well then lucky them
Does anyone know the story behind this thing? Is it genuine? Saw it at the Showcased event and it looked pretty damn good as far as I could tell.
The only thing that caught my eye was that it seemed to have a series 1 rear Nissan badge (old Nissan logo) but had a V.spec II badge which AFAIK = series II. Plus it has a V.spec II bonnet.
http://www.the-lowdown.com/s-tune-gtr/
not sure whether its a v-sepc or not.
it came up in conversation here with Kristian (Iron Chef) when discussing S-tunes and R-tunes
http://www.skylinesaustralia.com/forums/topic/393240-swap-n1-r34-gtr-for-r35/page__st__40
maybe it was built to V-spec spec when it went to Omori.
After seeing the car in person and speaking with the owner. We both take our cars to chasers. Yes it is real!
Yep, it's a real Nismo S-Tune.
I'm actually not sure if that is a real S-tune. I know it has the S-tune engine (I think) but I took a photo of this car back when it first arrived. as white lmgt4's, and no sticers on it :S
And yes, it was claimed to be the S-tune.
I will check my pics again, but I remember a Nismo Build Plate in the engine bay.
just came across this s-tune by total coincidence!
http://www.nagtroc.org/forums/index.php?/topic/33415-nismo-s-tune-r34-nissan-skyline-gt-r/
^^ Great R34 GTR but would prefer other type of wheels.
More pics of this car earlier this year:
Not too sure why it has a "fukuoka Factory" sticker on the air intake when clearly the engine build plate says Omori Factory.
And looks to be the car now has a Nismo Intercooler and Black LMGT4's.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
