Ah right. Quite lucky then! I've seen quite a few companies in Aus have the Z-Tune style one available to buy (not to mention the endless supply of cheap copies) but not this one. I do really like that one though. Can you still use the standard strut brace with that bonnet or have you got an aftermarket one?
All fits with the standard gear. luckily.
My old bonnet which is a knock off job sort of, of this one is at BodyForm MotorSports for sale. Difference is its fibreglass, still painted white and has bonnet pins in it as it didn't fit as perfectly as this one.
Here are some pics of the other bonnet:
hey all 34 drivers i was wondering what spring rates your all using, im in the market for some new coilovers and want to go a fair bit softer then what i have now
F6 R8, was thinking even as low as 5kg all round because the roads are sheit where i live and was wondering if thats going to be too soft. im thinking going BC fully adjustable coilovers for their price and info or help would be much appreciated
cheers
New one looks much more flush. Especially without the bonnet pins. And even better with the fact everything fits! Thanks mate.
What wheels?
Looks like work meisters/ssr professors but the spokes are thinner?
Liking it!
they're ROTA D2-EX
http://www.rotawheels.com.au/wheels/rota-d2-ex
rotas newest rip offs
definitely not real meisters
Highly doubt they'd be forged. Price tag looks to be around $1000 mark.
Might look into this when tax money comes back lol, can't justify to fork out ~$3k for real ones, being a uni student and all :(
edit: Not a R34 but damn they got my vote!
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
