Thanks fior the photos Terry, loving the N1!!!! Great plates as well. This car is Nissan+ Japanese racing at it's very best.
Me thinks perhaps there should be an N1 specific thread or photo thread, eh?
P.s. have you taken any more photos since your latest round of mods?
Looks tidy mate. A lot of people go with the D1 lip (viva garage/ebay) or the generic rubber lip (also ebay) was all the rage for a while :P
10354999_10152257328786527_4771776018402
My GTT. Work in progress.
Anyone recommend front/rear lips and where I can get them from?
I found the lip @ viva garage but I can't find any decent pics with them fitted par the ones on their site. Do you know of anyones car on here that has the lip and some decent pics?
  • 3 weeks later...
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
