Yeah Duncan with the amount of posts he has he's obviously a big contributor to the forum, not likely he's shot through especially considering he's sent everyones mat bar two. Just don't like sending money off that disappears without a word, hopefully Chuckie is alright and hopefully mats are on their way.
please tell me theres more of these left
Have you read the last page? There's still a couple of members who've paid money and are still waiting for a mat with no contact from seller. Mine's from November last year.
Just a heads up.....
  • 3 weeks later...
Thought I'd post a piccie of my new dashmat I just bought for my M35 Series 2.
web.jpg?ver=13343898430001
I got it from a US company called Dash Designs. Basically it's a 2005 Infiniti G35 dash cover custom made for right hand drive. I took a punt buying it as the G35 is essentially a left hand drive Skyline V35 and the V35 appears to have the same dash as the Stagea. Well, it fits perfectly, which means the V35 and M35 dash's must be identical. It has a cut-out for the auto headlight sensor but it doesn't have one for the passenger side sensor, which I'm not sure if it is a sensor at all. I also need to confirm that it doesn't affect the passenger airbag (It's really lightweight so I guess it wouldn't). The lump above the clock is a sensor (ETC?) of some sort which I hope to remove once I know it's not important. The mat is not stuck down at the moment. The small separate piece over the instrument binnacle definitely needs some velcro to hold it in place.
What I'm not sure of is whether it will fit a Series 1 M35 or V35 given they have a different clock surround and binnacle surround to the Series 2. The earlier model G35 in the US has an analogue clock below the climate control display so it would look odd.
Anyway the company was really helpful, they have many different fabrics and colours and can also embroid a logo or word on it. My one is a perforated suede look which ties in perfectly with the perforated leather seats and door trim.
Cheers
  • 4 weeks later...
  • 5 months later...
Not certain but I have seen factory-fitted dashmats with both the "flap" version and the cutout. As long as it's a "flap" which can fold up during airbag deployment, and the hinged section is above the airbag, then it should be OK?
  • 1 year later...
  • 2 years later...
On Fri Dec 07 2007 at 4:11 PM, chuckie said:
G`DAY ALL just to say i have 2 mat`s left.I will not have any more made at this time.CHEER`S chuckie
Hey mate just wondering if you still have any of these for sale.???
I know it's a long time ago but I am hoping.
Cheers pete
Okay so i've found a website that does dashmats, but not for stagea lol. I might try email them and see if they can do a custom one. Otherwise does anyone know if there are any similar dashes on other nissans that might roughly fit?
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
