  • Replies 93
I have just been told my coilovers have arrived and my rotors are lost in the TNT system somewhere....
Awesome.
Frak! Well, that post office had it in for you, at least you got one thing.......Im missing you! all alone at the house right now, while your continuing your holiday now without me!
BTW work sucks balls :)
Easy enough job... Especially the backs. Did my own at home with some wheel stands.
If you can get access to a hoist as offered I'd jump at it, makes things so much easier and you can inspect other things while you're at it.
Just make sure you get it all aligned and balanced after and you'll be ace. Was a 2 man job for me... well 2 persons, my self and my 16 year old brother. 2 backs went in within 2 hours, and I did some other crap behind the seats while at it.
Good luck, hahahaha!
LOL blonde/kinky idea stuck just then :sorcerer:
hehe! Im so imature
I can see this car having 25 people around it. Someone please set up a video camera!
Il do the videoing just give me a camera......heh heh seeing Man get dirty and stinky under a car gets me hot.
JKS im going to also take advantage of IANS fast Internet and Foxtell while you boys play with your toys.
Im looking for help :);):rofl::kiss::kiss::)
well, i can help you out with the ninja and the pirate, but i'm gonna have trouble finding the rest sorry :) if you can do without them then that's fine :P
well, now that you mention it, i might have some spare time to come round and help :P
will see whats happening that day (whenever it is) and might be able to help ;)
Guys
Im looking at getting this started this weekend. Saturday would be nice...
Is everyone availible?
i have to meet with a member of the opposite sex for lunch but i'll be free after about 3:30 - 4 ish
So theres a first time for everything then eh? :yes:
yeah.......(short silence)...........wait no its not!!! actually this one is just a very close friend. sunday i'm meeting a girl for lunch. will see what happens, will let you know anyway. i'm fine after that though
i dont know how many people you have already, but i will help you out if its next weekend. Suppose to be wiring up a temp gauge this weekend.
If the ladie in the short shorts is going to be there, then how long are you planning to take on this car......even with help.
Edited by Oblivion
Ian I can drop by if you despiratlly need to offer some guidence... But I really have to get a move on with my GT30 turbo conversion as the dyno day is only 7 weeks away and Im still in 100+ pieces... :/
But yeah i you need a little guidence I can probablly squeeze that for ya... I just cant stay more than say an hour...
dont you have a car to crawl back under? ;)
P.S i need some turbo's...
Yes I have many cars to crawl back under.....Migranes are preventing me from working though.
What turbos are you after? And what happened to those N1's that you bought?
instead of wasting space in ian's thread with unrelated stuff, i'll PM you ;)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
