Fuel Pump Poll
281 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Jason,trust Nengun as I have bought some things off them that were quite expensive and always turned up.Including the Nismo pump and am wrapped in it.Quiet,strong flow,and has all wires attached with it`s own frame.Simply pull the old one out and throw it away as the Nismo is complete.
Yea thats the main reason im wanting to get a nismo fuel pump, i had a gtr fuel pump in my old r32 gtst and everyone said it would be a straight bolt in, but it turned out that i needed to modify the bracket and filter bag, was a pain in the arse, so ive decided to spend a little bit extra this time and go for something that will bolt in with no hassles, i think i will place an order with nengun soon (might also get a blitz lm fmic kit and a few other bits and peices) everyone seems to trust them and ive never heard of anyone having a problem with them so thats good.
Cheers mate
  • Replies 65
1) Bosch 040 - internal
2) 33 GTST, mild mods, std turbo, approx 200kw
3)
- Ease of installation: pain in the ass to get the fuel new pump back into tank.
- Noise level in cabin: no extra noise
- Starting issues: need to prime sometimes but no dramas.
- 1/4 tank syndrome: none. Because I modified the bracket so that the intake sits in the same place as where the stock sock did.
cheers
1- r33gtr pump
2- 33gtst exhasut,air intake,boost controller under 200kw
installation was not too good as i couldnt use the r33 rubber mount on the gtr pump so i took it to a workshop and they did it (dont know if they used anything to be honest)
noise level is ridiculous... loud when priming, softer when idling but still audible
no starting issues
1/4 tank syndrome not sure as i just installed it
cheapest and ok for up to under 300kw would be either a walbro one or a 33gtr one both can be had for about $150 if u know where to look
bosch 040 is good too but i think isnt rated as high as the above 2
someone correct me if im wrong and they are around the 200 mark
1. Walbro lift pump tp swirl pot. 2 x bosch 910 280LPH @ 5bar direct voltage feed. New 3/8 fuel lines and fuel pressure gauge in dash standard FPR
2. R32 GTR track car stock turbos, injectors ( not for long ) PFC pods etc. Installation was not to bad as swirl pot in the boot
3. Sounds like a group of migets belting seven shades of shite out of the back of the car. Very glad for very loud exhaust and helmet.
4. no issue with 1/4 tank stuff with swirl pot.
yer id also like a definate answer about the 040, Im looking to run close to 300rwkw with some love juice (c16) and daily 260-280 on PULP, the 040 is rated at a 500hp pump, I just dont want it on edge when running near 300rwkw
Then theres the option of 044 (internally) Dont really want a swirl pot and ext pump....
This is on a 20 BTW
-Jez
  • 3 years later...
  • 11 months later...
Thread dig.
I've recently purchased a bosch 044 already setup in the factory cradle from a 32 gtr to go in my 32 gtr. just want to know if anyone has had any problems with having these mounted in-tank at all?
Need a piece of advice...when installing aftermarket pumps do you need a Fuel pressure regulator? When does one need an FPR????
Cheers
Pretty much never unless you are too stooge to get big enough injectors and compensate by increasing rail pressure, that or you are running some stupid hp and decide a rising rate makes things easier to tune.
  • 2 months later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
