I've convinced my mate he needs a project car whilst he's saving for an XR6T (he's a ford person :no: ). We're both interested in rebuilding/converting something and his old man has a fair bit of expertise.
The general consensus was it must be a sleeper, must be reasonably quick and be on the cheap side. If it runs a flat 14 he should be happy (currently on par with my R32 :) ) but if it manages to go quicker its a bonus.
He drives an LPG Falcon so fuel economy isn't a worry as it won't be daily driven. 4 doors is a bonus, but not a necessity. We both love the note of a V8 but it does detract from the sleeper value of the car. Turbo would also be nice. RWD is prefered
The first idea was a VL. We found one with a recond gearbox and blown head gasket for cheap. The idea was to do a RB30DET conversion using a stock bottom end and keep it looking like a shit box. Only problems would be the drivetrain isn't up to the power so it might start getting expensive and his parents hate Commodores and are refusing to have it parked outside there house :) (which is fair enough)
I suggested an aus spec R31 but he doesn't think it has the same sleeper value as a VL. I'm yet to pitch the idea of the FJ20 turbo Datsun ute (my favorite) or a supercharged 4A corolla. A torana may be an option but it's not really much of a sleeper with a V8 inside it.
Budget is probably about 4-5 grand for the whole thing. Definately wouldn't be spending any of that on aesthetics :P
Can anyone suggest any other cheap cars to do up?
If anyone can come up with some mini car (moke or lada style :D ) that you can shoehorn some kind of ridiculous engine into I'd love to hear it.
Cheers
-Matt
https://www.sau.com.au/forums/topic/149534-need-a-project-car/
  • Replies 44
Posted Images
^Haha those things are granny mobile's to the max.. Reminds me of an AMC Gremlin
FJ20> MR30 hatchback... Engine should bolt-in with DR30 cross member
MX83 Cressida with 1JZ 1/2 cut. Can be done very cheaply if you don't mind the auto.
Edited by Drift_Limo
Nissan Patrol?
it's dirty cheap nowdays, you could turbo it and see it fly,
see this for example: http://www.skylinesaustralia.com/forums/in...howtopic=148705
Buy 3l verison, drop the motor off vl turbo after these who has spent loads and see if it is faster than 32 gtst.
If 4.2ltr, you could pick 1 with lpg and use lpg mixer to fuel it no ecu needed, boost it to 10 psi and enjoy.
Post up if he decides to do the cheap sleeper project.
Cheers
ea/eb falcon with turbo bolted on..
in fact there was/is? one for sale very recently for about $5k.. looked as grandpa as you could get. In fact, if anything it was too clean.
VL's are hardly 'sleeper'.. If anything the one car cops would pick on..
4 to 5 K is not enough money for a sleeper, let alone a motor for a sleeper.
All you gonna have is heart ache and worries.
By a car that is already fast and cheap..ie Q45 Infinity..around 7K
This then can be worked on slightly to increase power..ie zorst, intake,re-chip/comp.etc.
0 to 100 in around 5.5 seconds,1/4 Mile in 14....and this is in stock form
My 2c
At the last dyno day in NSW we saw a recently converted bright yellow and rust VB commodore wagon, with roofracks and all....
RB20 inside with VG30 on the side...
aparently he wanted to do it to show the "ricers" a thing or 2 about drifting on the track...
sleeper and a half
people look at you like your a bogan, untill they realise it goes like shit off a shovel
DRIFT WAGON FTW
Haysey, where are you getting all these pics from? Friggen awesome! :(
Has anyone ever done up a R31 Skyline wagon?
According to redbook they have the same kerb weight as an R32 GTS-T. A turbo on the RB30 would make it bloody quick in a straight line. You could probably drift it aswell :P
Keep em coming :D
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
