  • Replies 182
yeah not sure about the forcast with those temps and my std tyres they would melt in now time so i guess I would have to take it easy...but still will be fun.
Car tuned, pulling good torque - ready for action.
any of you guys got a video camera? I'll be comin down to spec, so I could film for you...I know justin wants footage of his car...but no camera...
I'll be bringing mine down, so I'll see what happens. I'm also bringing down some bullet cams that I want to place in wheel wells looking a brakes, and under the bonnet, to get some fill for videos.
Thats awesome, bullet cameras, looking forward to seeing that footage :(
