  • 3 years later...
Yup !!
After fitted all those necessary power up goodies, then the traction issue. How about roll the rear guards as wide as possible, then the widess possible rear tires you can fit, say 285 - 305mm wide. hmm MADDD !!
Then you can drop the clutch at around 6000rpm with full traction you setted up for like my mates fat ass gts-t33. See !! POWER + TRACTION = 2FAST 2FURIOUS ........... Good luck mate.... cheers
Yup !!
lol
* Exhaust Cam Gear ($250)
* Boost to 10-12psi ($200)
* PowerFC ($2000)
* Good quality tyres ($1100)!
* Pineapples ($150)
Forget the bigger turbo, the extra power you make out of it will be lost in hitting boost and putting the power to the ground. You want a constant steady power curve to give you instant power and the stock turbo will deliver more than enuff power for this.
If your -really- after a 'bigger' turbo just get the stock turbo hiflowed, once again it will deliver more than enuff power and will boost up similar to the stock turbo.
Now how many people spend heaps of money on their engine but forget that somehow they actually have to put all that power to the ground? Do yourself a favour and buy a set of good quality tyres (back atleast).
Pineapples will give the rear end better squat and will force the car into launching harder in a straight line which is exactly what you need.
Note: The only experience I have is reading forums, not putting theory into practice. But thats only until I get a good set of tyres.
Out of interest...how would you rate your old R33 to the GTR in the street? Your GTST with semi slicks for daily driving wold had to have been a weapon....it had PUNCH!!! I cried when i got back in my car :)
"It is pretty difficult to beat a WRX off the line.. Even GTR's have trouble.. WRX's are full time 4wd that is why they break so many gearboxes."
I manage to keep most Rexes honest in the wet, and the dry.....90% of the time. Grip would have to be the big one and how your car puts power to the ground.
  • 3 months later...
thanx guys i get da drift... what exactly are pineapples..?
LOL..
Look save your money...and trade your car for GTR.they rarely line them up..
:O:glare::)
Weir, I posted this up in another thread....WT.
The curse is back......lol
  • 2 months later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
