Presents
SAU DECA Day - 2007 Round 1
When: Saturday Feb 10th
Where: DECA Facilities Shepparton
Cost: $75.00
Max entries: 45 + reserves
Entry Form and Sup Req's
Event Schedule
Event Schedule - Mirror
Anyone paying by cheque MUST make the cheque out to Skylines Australia Victoria. Cheques made out to anything else WILL BE REJECTED
Current Entries
1 Andrew Richmond R34 GTR
2 Matt Lowth EVO 9
3 Dave Maranauci XR6T
4 Justine Schuller* S15
5 Gary Matthews** WRX
6 Sandeep Aberwickrema*** 300zx
7 David Lee R33 GTR
8 Andrew Dean R33 GTR
9 Aaron Miles BMW M5
10 Peter Blythe R34 GTT
11 Phillip Robinson Echo
12 Chris Law R33 GTST
13 Joe Percy 180SX
14 Adam Newton* S15
15 Alycia Matthews** WRX
16 Guy Baxter*** 300zx
17 Jeff Beaumont EVO 9
18 Alan King EVO 7
19 James Ward EVO 8MR
20 Brenton Homer WRX
21 Matt Waite Celica
22 Muhammad Ziad EVO 8MR
23 Aaron Tan S15
24 Evan Boyak WRX
25 Aaron Foo EVO 9
26 Chris Thomson R33 GTR
27 Scott Bailey TX5
28 John Andrews R33 GTR
29 Scott Andrews R33 GTST
30 Tom Giordano R32 GTST
31 Justin Marcus R33 GTST
32 Russell Cunningham R32 GTST
33 Matt Phillips R33 GTST
34 Michael Dessman R33 GTST
35 Sam Lothringer R33 GTST
36 Andrew Collins Box
37 Alan Calleja R33 GTST
38 Jason T e h R33 GTST
39 Jarrod Moore R32 GTST
40 Nick Edlin R33 GTST
41 Troy Brisby R32 GTST
42 Ryan Bell 180SX
43 Gareth Evans R32 GTR
44 Adam Nightingale R34 GTT
45 Shan Moorth R32 GTST
46 Wayne Sterling R33 GTST
47 Ben Lippa R33 GTST
48 Naveed Ahmed Stagea
49 Craig Moor Kakomoto
50 Russell Dunn R33 GTST
Emergencies
51 Simon Husk R32 GTST
52 Craig Esposito R33 GTST
53 Berin Connell R33 GTST
54 Tony Buckland WRX
https://www.sau.com.au/forums/topic/151753-carsales-presents-sau-deca-day/
  • Replies 204
Posted Images
Entries from J-Spec are being faxed now and will include:
Ben Lippa - Skyline R33
Craig Moor - Skyline R33
Russell Dunn - Skyline R33
Shan Moorthy - Skyline R32
Naveed Ahmed - Skyline R33
Wayne Sterling - Skyline R33
:unsure:
PMSL - Shan is the black sheep of the family in his 32 :huh:
umm can i put my form in but pay on friday (dont get pay until then) ??? also i know its a repeat question but can i apply for AASA licence on the day or do i have to get one before.
thankx
Its fine to get a AASA licesnse on the day - but it will make it 10 times easier in the morning if you have already filled in the form and if you bring the correct $$ with you.
:unsure:
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
