i still can't really see any point to using forged pistons in a street car. but each to their own, the extra $600 or so for the build might help you sleep at night anyway, if so it's money well spent i reckon.
we'll see how long my casties last and what power i put down with them reliably anyway, might help some people see the light :)
p.s. had my first run with a fastish car on the weekend - "200rwkw" 180sx down the gold coast. anyway murdered him through 2nd and 3rd - even with the laggiest turbo known to man. i really need a tune too.
hey!
I got casties in my rb30 too. did you change the rod bolts at all? because mine are stock also.
How much power have you made ??
Mine was tuned to 16psi only because i am too scared of breaking the engine. if i was game id run it to 22psi and roll off another hundred hp at the rear wheels at least.. but yeah im scared of the cast comming to pieces or something lol
tell me the details of your engine ?? will be interesting for my next power up :O
You want a 0 deck clearance. At top dead center the piston is flush with the top of the block.
sounds good, you have been there done that so all the info is pretty helpfull
whats a formula to work out comp ratio and what ratio were your pistons ideally, had they been in an rb25
hey!
tell me the details of your engine ?? will be interesting for my next power up ;)
No i didn't bother changing the rod bolts. Have you ever heard of rod bolts breaking on an RB30? cause i hadn't :P
i have only a vague idea of what power my engine is making as it's still running an RB25 base map for the time being. as i mentioned, it REALLY needs a tune. but i'm not going to bother yet, not until my blower is on the engine and piped up.
basically i have a built RB30DET with custom manifolds and a GT40 turbo with 1.34!!! rear housing at the moment. it was all built to run as a twincharge with an Eaton supercharger, hence why the rear housing on the turbo is so large. it's still remarkably good to drive though, even with RB25DE cams and no tune the top-end power is astounding.
Just spent over an hour reading this thread.. tired as hell. sorry if i missed it but if the RB25/30 conversion is done, can a R33 gtst power FC tune it all up or do you have to go with another type of comp?
yeh mate i run gts-t pfc with my 30det
got mine back yesterday, has a very mean "serious business" exhaust note haha.
No boost as yet until it's run in, but even so definatly has more balls than the n/a i drive daily.
Just itching to get some boost into it though. :devil:
head restrictors
does anyone have a pick of the hole i have to weld up and the the one i have to put the restirctor in
also when do i get one of these restrictors
pete
There are 2 oil feed galeries in the block that mate up to matching galleries in the head. They are between #2 & #3 and #4 & #5. Block the rear one and restrict the front one. A piece of brass rod drilled to the right size hole works well as a restrictor.
:( cheers :D
Just itching to get some boost into it though. :(
good to hear gav, about time! Can't wait to see it!
Easier to tap the rear for a grub screw or put a solid piece of brass in to plug the hole - than to weld it up.
head restrictors
pete
Just a question regarding pistons and compression ratio stuff for this conversion. Cubes I think stated a page or so ago that the compression height for a rb30 normally was 1.26". Now the CP pistons for the conversion I got have a compression height according to the spec sheet of 1.28". So my understanding is that the piston will actually sit .020" (.5mm) outside of the bore when at TDC. Is that correct?
They reckon with a 1.2mm (.048") headgasket you should get about 8.3:1, now this worked out in my calcs if the head cc's up to about 64cc. If your head cc's up about 62cc then i think i worked it out to be about 8.5:1CR. I just want to check the formula here so hopefully im working this out right.
CR = 1pot vol+head cc+deck height cc / head cc+deck height cc
So if the piston sits .020" outta the bore then I should take that away from the headgasket thickness im running or plan on running and work it out from there...eg if i used a 1.5mm gasket, minus that .020" i would use 1mm in the equation to work out the CR, even though Im using a 1.5mm gasket.
Does that sound correct? Or have I confused myself here?
I am not 100% sure what the std rb30 comp height is to achieve a zero deck clearance.
The best way to know what comp ratio you will have is to buy your pistons last. Measure everything up then select what pin height etc you require.
I checked acl website and for a set of forged pistons for rb30et they stated on their spec sheet that the compression height is 1.261"
Im assuming the forged piston is just a copy of the std one and maintains all std specs. So 1.26" is pretty close to std.
Most of the pistons mentioned in this thread have different crown design/machining. Some are dished, some raised, some have small valve relief fly cuts, some have large ones. All of these affect the compression ratio.
Compression height is useless without knowing the dome cc's.
:) cheers :P
:D cheers :)
how do we take the dome cc's into account when measuring the compression ratio
how would using the rb25 pistons also affect them when the block is decked to suit?
The discussion is piston selection for the rb30det.
First thing we need to do is select a suitable compression height which is 1.260". THEN we worry about the dome or negative done to achieve the comp ratio we are after.
Without a dome and zero deck clearance you will be running some where around a 7:1 comp ratio. :
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
