just a couple of questions.. probably been covered before but spent the last 20 minutes searching and came up with a few hits but no solutions :P
first of all, the oil drain that is located behind the exhaust cam gear, are you guys just T'ing it back into the turbo oil drain? Is this something to do with the PCV system so it would need another hole tapped so it can drain back into the sump?
and last one, the two green water temp sensors (i think that's what they are..) that are present on the rb25 have no place on the rb30 block, and no place machined flat where they could be tapped in (from first impressions anyway), are they being T'd into where the radiater in and out pipes are attatched?
cheers guys,
mark :laugh:
cheers guys,
mark :laugh:
Best to put the front oil drain back into the sump to remove any chance of a back caused by the frothy oil from the turbo return, you can T it but you want the oil back down to the sump as fast as possible.
the green sensors are the knock sensors - i have attached a pic that i got from this thread that shows their locations
EDIT: Yes i'm retarded, there were spots for them there the whole time, thanks for the info though, much appreciated :miner: <begin flame now>
Edited by aphid
Hi Guys,
I'm now a proud owner of an RB25/30. Got my baby back about 2 weeks ago and am now running her in. I've just got the standard 25 turbo in atm but I'm very impressed with the torque. Dan from Elite Racing Developments did a great job. Here's some pics.
mind if i ask how much if cost you?
It's only legal in 31's.
but
You can only get it legal in later models if you convert it to lpg. -EPA bullshit.
or
But if its in a later model and the RB20/25/26 engine number happens to appear on the Rb30 block and the RB30 casting also happens to have been ground down then you wont need a mod plate. As far as the DOT is concerned it is still the original motor. :laugh:
Edited by Alf
Just a quick Question guys,
If I allready have a 3.5" Cat-back exhaust +3"High flow cat+ 3"Dump+front pipe (I think the neck/flange of the front pipe is 2.5")
would there be any benefit upgrading the cat, front and dump pipe to 3.5" as well?
this is on a RB30+HKS2535
(I know I know, its too small, say for future upgrades GT30R or GT35)
well if you upgrade to these other turbo's later (gt30r or GT35) then your front pipes/dump pipe will change anyway so i wouldnt use that argument.
i would say that the extra exhaust flow from the 3L will benefit from the larger dump pipe and Cat - but would wait til you upgrade to save costs
Cubes has busted me and it's time to come clean so enough lurking and enjoying the posts.
Last month I decided to go the RB30 route in the 25t track barge. The bottom end is an SII DE with still perfect 86mm bores. I then decided to buy a 26 head, use a spare complete intake and use my steel wheel turbos coming off my GTR. The GTR makes 260rwkw with these on 1 bar so should have a little more in them on the 26/30. Of course doing this it only makes sense to use decent rods and pistons so forged Spool rods and hi-comp ACL pistons are to be used. I'll go with the hi/low adjusters on the front, long pump drive on the crank, baffled sump, 1.25mm restrictor, Cometic head gasket, oil cooler, 044 with 1.5L swirl pot and GTR feed pump. I'll stay with the Hybrid monster cooler as that works well already. After I have gotten used to it I'll probably shove in bigger injectors and turbos and try to run up at the 350rwkw mark, but maintaining lots down low.
As always I'll build it myself but will try a new machinist to get it done fast as it has to drive to Brisbane on the 3rd of March.
All I can say is I'm looking forward to the fun.
Oh yeh...another one bites the dust. Slowly everyone will get converted to the rb30 side.
And realise that queensland is truly gods country...as Spoolup has already mentioned.
Edited by r33_racer
Just moving home Brad (if I have pistons to make the motor go - nudge nudge) and it's always been both home and gods country to me. No rain here in sh*tsville....err I mean Melbourne. Must be all up at Ingham.
Mike, this project can be partly blamed on you. Love the idea of a dedicated class racing 25t. Unfortunately I have another project awaiting involving a small convertible and a quad cam V8.........
hey mate, whats the part number of the acl pistons your using?>
v8 powered mx5....aww yeh. That was with a removable tube chassis front end if i remember correctly?
Hey with your expertise...could you effectively trick out a skyline with sweet james bond like gadgetry and weapons? Missiles, mini guns and the sort? Ive always wondered if anyone had done it or if it was technically possible/practical.
ACL pistons? Clicky the link in the sig above your post.
Mark, what's up? Bored with ACT. Hows that 26/30 coming along?
Brad, thanks.
Mike, does an RB25DETT count? Surely the 26/30 is near enough? I saw a LAV with a vulcan on top firing over the side. I thought it would roll over at one point. Anything is possible with money....the Bond Die another Day cars actually had the stuff in them, and had to run tiny motors to fit it so possibly not practical. Great ep of House tonight BTW.
Anyway, back on topic....which injector plugs should I source to make a loom for the 26 injectors? I know I should get off my ass and go into the EFI shop but it's easier to just ask and they are closed this time of night..
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
