lol...
so fuel hose ( what size ) and speedlow fittings :-)
Do you run it underbody along the old line ?
From memory, Dash 6 fittings, they bolt straigh to the pump and 9 mm ID hose.
Under the car using the standard fuel rail clamps.
I use the standard feed pipework as the return and remove the standard return pipework.
On the R32GTST, I used the HICAS pipework, it was there, in the right place and plenty big enough.
:rofl: cheers :)
yes Im going to do as Gary suggested before touching or upgrading pumps.
I want to go over 500rwhp even if just for wank factor :-)
Im getting a scanner tomorrow so should have something up over the weekend
Are you going to try run bigger fuel line?
Get that scanner working, im keen to compare...
Just got back from mercury before we ran the car up with kyle and with a few little adjustments with no water/meth on 18psi we got 340rwkws out of it.
Gotta change a few things like wastegate spring is too weak (7psi spring) and boost is dropping up high to 17psi, so going for 14 and 7 for 21psi. Im hoping that with the extra boost some more timing and the water/meth injection which should allow the extra timing/boost we can crack 400rwkws, even though it aint knocking yet. Im guessing with a full tune without water/meth we can get to 370 and then the last 30 with the injection.
Edited by r33_racer
Thanks Cubes
r33 racer well picked up....you are on the ball, but it was just to say well done since i hadn't heard anything and was keeping an eye out on the thread with his updates.
Its always good to see a car up and running. You would be surprised how many people have a collection of parts in their garage/cupboard.
haha ISL33P actually i already knew he had one on his car previously. I just said it like that so it seemed i was highly intuitive. I can relate to the amount of parts in the garage though, we are upto our necks in spare junk.
Yeh the problem was from a boost leak where the i/c pipe went into the silicon hose on the tank of the i/c - inlet side. The whole system wouldnt hold 5psi. So i fabbed up a new inlet i/c pipe which fixed that. So we are outta the woods for now. At the moment were getting full boost at about 4500rpm, which is a big difference in lag, we should be around the 3700rpm fullboost, which will be 21psi. Were hoping to just control boost with springs and nothing else, as the wastegate is now directly running off our turbine housing. So hopefully on the next tune fullboost will be achieved earlier then 4500rpm. I should have got the print out and posted it on here.
whooo hoo - you must be a happy chappy having finally sorted it Michael.
Its always a process of elimination with these things, its just the frustration of having to sort through all the variables to finally find the root of the cause. I know it was driving me loopy trying to find my problem.
When I get some tyres sorted drop around and Ill take you for a spin.
Thanks Ariel - Your plenum obviously works well :-) Highly recommended
quote name='ISL33P' date='1 Mar 2007, 10:10 PM' post='2946307']
Thanks Cubes
shit yeh brad...its good when problems get sorted. Dont have to stress anymore about any wild theories which would end up in engine pull out to fix.
And shit yeh to the spin...woot. Its going to be a headspin machine for sure.
Ok Guys after reading alot about oil setups, i'm a bit worried about my sump, i am retrofitting a rb30det into an old Lc gtr torana, the sump has been modified dramaticly to fit, it looks like this
Now the front of the pan is pretty thin i am worried about not being able to fit any baffles(not enough room), so i might get a fair bit of crank dipping, also the oil may take it's time getting back to the pickup area (which is quite small doesn't look like it can hold much ) does anyone know if these are going to be an issue? the motors going to be putting out around 500rwhp
Ive been looking at dry sump setups just incase. and i have an idea... if i run a scavanger pump from the bottom of the pickup area in the sump to a remote tank situated above the engine. then at the bottom of that remote tank have a large pipe gravity feeding to the exsisting n1 oil pump pickup,
Will the n1 pump have enough suction to pull oil from the top remote tank.. it will be pulling basicly strait down, so gravity will be on it's side..
Is the sump going to cause me problems?
Or does it look like it's going to be fine
Bought some Toyo R888's today - holy crap what a difference. Its like driving the millenium falcon now, all the power gets to the road with barely any wheel spin.
Awesome !!
Probably break something in the drive train soon now :-)
New tyres make the car a whole lot faster hey Brad.
You get a scan of that graph??
As far as I know Wiesco only make one type of RB25 piston - so you have no choice.
If you are going to use there RB25 piston you need to work backwards and calculate the comp ratio you will have with them, then figure out what thickness head gasket you will need to achieve the comp ratio you actually want.
PISTONS:
i want to clear this up, if I use weisco rb25det pistons, what compression should i order, of the shelf version, suggestions?
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
