Wow finally read it all, took around 2-3 weeks haha. Awesome thread!
Anyhow, I have a spare RB30 short motor if anybody is interested in adelaide. It's a S2 from an R31 and appears to be good condition. I bought it to do the conversion, but have since purchased a different motor to use for ease and because of money. haha.
Yeah, its all here minus the sump so if anyone is interested for a conversion just send a PM!
Jack
Brad, keep a set of CP RB30 9:1 pistons and Spool rods for me. Through sheer luck a 26 head and intake manifold dropped into my lap so I might as well build another and offer someone the gift of 26/30 goodness.
Hey guys. I made a topic out of this but havent yet got a a reply and thought this might be a better place to ask the question. I hope thats ok
Recently i got my fully built rb25/30 up and running after a year long build. The only untouched component in my engine bay is the fuel rail everything else is either aftermarket or had work done to it. I'm using a haltech e11v2 ecu & atm the car is load limited. Basically what happens is at 6,500rpm the engine will stop reving any faster unless the wheels are spinning in which case the load is taken off the engine and it will rev out. Its not a harsh limiter it just will stop revving any faster and the exhaust sounds like it flutters very fast. The ecu has an inbuilt rev and boost limiter but they are both set above wastegate pressure & the current rev limit.
I didnt relise until recently but i found out a few of my mates using different model haltechs have had numerous issues. I now know i should of cashed out the extra money and gone a motec but whats done is done. Rob at 101 is a really smart guy and he told me he'd be able to work it out eventually but the longer he spends working it out on the dyno they more my bill will be. I was hoping someone else might of come across this before and already worked out the answer.
The answer to what?
What's the question/problem?
have an rb30 twin cam in a 32 and would like to put a brake master cylinder brace on but with the different height of the motor i'm thinking the off the shelf ones won't fit?
what have other people in my position done?
Cheers!
I have a Cusco master cylinder brace and it all fits fine with the rb30 in there.
ah cool, thought u may have had issues with the different heights of the motor.
Where did you and scooby get yours from?
Do u have pics, i may have a go at making one myself.
Cheers!
Hi Ash, got mine from Jap auctions. I've got a spare Nismo one without the stopper you can have for $50 plus postage. Probably not worth making one for that price I just don't need it.
what exactly is the stopper? do i need it and will it suit a 32?
Has anyone fitted a high energy HE2112 VL 3.0L Commodore Super Pan $458.53* into a 32 without having to use a custom made front sway bar?
http://highenergy.com.au/index.php?module=...5539231984-1177
A few pages back, Al had problems with his HE8124 Pro-Circuit 3.0 VL/Nissan, 4 Gates, 7L, P/Up clearing the sway bar.
Well, my engine had its "dummy fit" yesterday and all the clearances etc checked. All good to be assembled next week. I'm starting to think i should of gone 280 cams instead of the 264/272 option after reading around the net. One thing that was picked up was i have a R34 RB26 head and i got cams to suit the R32/33 RB26 head for ease of finding a crank angle sensor later on. Well the HKS valve springs to suit my cams held 7psi less than the R34 factory valve springs. I now have aftermarket ones that almost hold double the pressure. This stuff is way over my head but by memory, the HKS springs held 38psi so the stock ones were 7 psi above that and the new ones (can't remember the brand) held 75psi. I don't know what these numbers mean but more is better i presume. The ATI balancer looks pretty too. I hope my stall converter is big enough for the T04z as well.
I am finding it hard to choose between the Haltech E11 v2 or EMS 6860. Any help from you guys would be appreciated. The car will be primarily a drag car. I am wanting to have a low boost level for 1st and then a higher setting for 2nd and top gears. Also i would like to run 2 seperate maps if possible maybe even 3 switchable seperate maps.
Cheers
Steve
Well mine is back on the road; but in run-in tune. :D
Couldn't be happier, i keep grinning every time i press the GO peddle.
Below is a few pics of the completed engine bay and the run-in tune. The boost is very responsive, and that's only controlled by the actuator (no bleed valve, EBC or restricters) Once i have completed 1000km, it will be wound up to 20psi, then the fun really begins :)
    • Good tips, will get on those tomorrow. When doing the maintenance I did move a few of those connectors around, and things that are old tend to not like moving around. (Like me).
    • Don't try it. It will be shit. Better chance of damaging the engine than gaining any knowledge about the old one. Maybe, but unlikely, especially if the O2 sensor is working. You can use NissDataScan to look at the stock ECU.   Cleaning the AFM is seldom necessary and seldom helps. The R35 coil & loom conversion should eliminate dud coils or plugs. But as you still have misses - look to the plug where the coil loom connects to the engine loom, and the CAS plug. Need quality connections there. Also look to injector plugs. And the AFM plug while you're at it. Also look to whether your injectors are clean and flowing evenly. Get them out and onto a testbench.
    • Good to know, I feel like I am in for a rollercoaster ride that looks like a sine wave.
    • You'll fit right in. Acceptance is the first step.
    • Hey folks. I've been lurking and browsing the forum for a while, since I got into my head that I wanted a skyline. Having purchased an overpriced completely stock GTT, (only "mods" it has is HKS pod filter and catback) now that it became legal in the US, it was all glorious and sututu noises here and there. But then I wanted to do things right and went to do basic maintenance. After all the fluids, filters done, I did the spark plugs, that's when the problems started.. First the car started spluttering at around 4.5k RPM. Which I gapped down the new plugs and that solved the sputter there, but the car now always misfires at idle with pops when lifting off and shifting 2nd to 3rd. Similar to the issues in this recent thread. I've been banging my head against the wall, reading the threads here and trying suggestions for a couple months now, so decided to start this one to explain exactly what I tried and what is going on. The symptoms of the issue: Idle and low revs misfiring intermittently. You can hear the exhaust tone change and the shakes on the shifter knob. It happens frequently, but doesn't seem to have a rhythm to it. Pops when backing off throttle. It pops and or burbles almost feels like it spits fire when it pops. (Happens mostly in 3rd gear at around 2k RPM). When under load and after 6k RPM, it also pops when shifting from 2nd to 3rd. There's a ticking noise at around 2k RPM in 2nd gear going downhill, seems unrelated though but I am out of educated and downright dumb guesses. Not noticeable lack of power when putting the car into load. The attempted diagnosis and solutions: Unplugging coils when the car is running This did nothing to change the idling and tone shift for every cylinder. Checking the exhaust headers with thermometer They all are within what I'd say it is margin of error of the laser thermometer New spark plugs Tossed two new sets, copper, iridium and using the old ones, still misfiring, even re gapped to 0.8mm, still same thing. MAF cleaned with the "specific" spray cleaner No changes in the issues what so ever. Brand new loom and r35 coil conversion (was going to add the r35 coils anyway) car runs arguably better, still misfires, but seems like does less frequently. Placebo? Code 21 now being thrown, thanks nissan gods. Removed the CAS to check the shaft for play or anything. CAS seems all fine, nothing that indicates any issue, visually speaking. Things to attempted next: Ordered a new MAF (chinesium from Amazon, to be able to return regardless of result). Fuel with proper gas, maybe it is this California water that they sell as gas that is to blame? Plugin the link ECU and check the info using the built in base map. Go back to BMW and eat my rob bearing breakfast without milky oil mixture.   Do any of you have experienced anything like this or have any suggestion?
