Yes if going 26/30 then use the 33 GTR engine loom and PFC, you will also need all the appropriate sensors off the 26 (water temp sender is different, need the intake temp sensor, different coils if yours is a series 2 25 etc etc).
It will cost a pretty penny but if you're prepared to pay, then by all means go for it. Keeping your 25DET head is the cheapest/easiest way to go and the stock throttlebody/plenum are good for nearly 500rwhp.
Thanks very much for that bubba! Clears up alot of confusion for me. Will let you know how i go with the 26/30 into GTST. Cheers.
  • 1 month later...
Not sure if I've missed it somewhere along the way.... but is it absolutely essential to get an RB30ET block, pistons, rods and crank?
Could you get away with an RB30E block and drill the oil/water lines, and get 3rd party pistons and still use the RB30E rods and crank?
If so... makes finding a suitable block a lot easier if all you have to do is tap it for the oil and water feeds.
I have an RB25DET on the way and want to do this conversion.... just trying to figure out the cheapest way to go about it, and whether I need to keep ANYTHING from the RB25DET bottom-end (e.g. ancillaries, accessories like power steering and aircon).
Then again, if an RB30ET motor can be had relatively cheap, would probably save time stuffing around... how much do they go for these days, and how available are they? Wreckers etc.....
have you even read the thread? it covers everything you have asked.
what sump do i use for rb25-30 in a r33 gtst? do i use rb30 or rb25? wont be lowering the engine coz ive got a greedy plenum going on at same time.
and will it run properly on standard rb25det computer? its a fresh motor so will need to run it in but im concerned it might go into rich and retard too often and not allow the rings to bed in from being too rich. (read from another guy selling a rb25 block that it didnt bed in properly coz of running too rich) i have a wolf3d computer but dont have enough to tune it and buy injectors and crap right now and only wanna tune it once and i dont have big turbo either so just wanna get it running on standard ecu if it will work.
thanks guys. wanna put my sump on asap so wanna find out about that. been doing this conversion for ages. need some last info
does anyone know how much the rb25 tensioners are? i do use 2 rb25 tensioners for the timing belt right?
it will run on the stock computer but don't expect it to run brilliantly. the larger capacity will push the ecu map into the safety zones of the standard maps so you lose a lot of ignition timing and it runs rich.
you can use either the RB25 sump (remove the 3 fins that stand up as the crank will hit them) or the RB30 sump (no mods required)
my engine uses two tensioners but some people don't like that method.
Hi Guy`s just a few RB 30 oil pump & block part`s i got in,
this goes in Block ,Value Reg Set ,part number 15241-40f00,
oil pump RB30 Valve Regulator part number 15132-42L00,
post-36964-1273122400_thumb.jpghope this will help some one out ,
Cheer`s Chuckie.
  • 4 weeks later...
hey there guys, i read the forum and i got lost along the way, i am in the process of a rb25/30 build. i have just reassembeld my r32 rb25 na head. standard valve springs and cams etc. for my 30 block, i plan to use the standard pistons, use chromolly top rings, and turbo piston rings, with standard rods and crank, acl race bearings and big ends.also use a factory rb 26dett head gasket. and i do not plan to get the head or block plained as they came out of good running cars. i plan to run a single turbo application with sard injectors, a custom front face plenum, top mount turb etc. i plan to use a microtech ecu or similar.
was wondering if anyone has done a build along the same lines. i am constantly confused with comments about these builds. i want info from people who have done a 25/30 build themselves, not random guesses or opinions. basically i want to know if this setup would work.
is there any modifcation to galleries etc? i think i know a brief amount of what im doing, i just want a proffesional opinion. thanks guys
  • 1 month later...
Hey guys, I have posted this a few times in the past but I thought some 1 here may be able to answer it. so please excuse my copy and paste
I was hoping I may be able to ask for some advice regarding setting up standard Neo cams on a bastardized RB30DET that I have recently built and dropped into my R34.
When I built the motor I had a momentary lapse of reason and never fitted my adjustable exhaust cam gear. My timing is clearly out, but all timing marks line up and the VCT is working also (marks appear dodgy and I don't trust them). I intend on dialing the cams in properly once and for all with a mag base dial indicator but to do that I need to know the correct STANDARD settings for a RB25 Neo.
standard RB25DET NEO Camshaft duration 236°in, 232°ex lift: 8.4mm in, 8.7mm ex
Do you know what degree's in relation to TDC the intake cam is set to or @ 0.040" of lift? Either should get me the correct position and then I can move the exhaust position while sitting on the dyno.
Thanks in advance.
Chris
  • 4 weeks later...
Thanks in advance.
Chris
I used a R34 neo head and when I put in the stock cam pulleys and a rb30 block the stock timing marks are a bit wierd at aligning but I just had it tuned and it's running fine now on all standard cam pulleys you say My timing is clearly out, but all timing marks line up and the VCT is working.... if the timing marks line up as close as you can get them the engine will work fine
Edited by DYNOBUSTER
  • 4 weeks later...
I wont bother going in to the XR specs as we are comparing apples and apples. :)
Specs from here!
---- EL & AU Standard Ford 4ltr
157kW @ 4900 rpm.
357Nm @ 3000 rpm.
---- EL Standard Ford V8 5ltr.
EL - 165kw @ 4500 rpm.
EL - 388Nm @ 3000 rpm.
---- AU Standard Ford V8 5ltr.
175kw @ 4600rpm
395Nm @ 3000rpm
VS Commodore Specs - From Here
---- Standard V6
147 kW @ 5200 RPM
304 Nm @ 3600 RPM
---- Standard V8 5ltr
165 kW @ 4400 RPM - 168kw for Series II -- wow
385 Nm @ 3600 RPM
Sorry to get a bit off topic peoples.. :blink:
Oh and if you ask why a VS will blow away a EL.. Slap a Manual in the El and a Manual in the VS then watch the EL fly..
The Auto g/boxes in the Falcoons are geared extremly bad.. 80km's in first isn't to good.
If you ask why a VS Auto will blow away a EL Auto.. The Ford's gearing is a lot longer than the Commodores.
Slap a Manual in the EL and you will be suprised how it actually kicks the VS Manual's arse :ermm: If you ever come up against a Manual EL you will notice how quick they are off the line without stalling it up.. A VS V8 has no chance against it and has to reel it in very very slowly.
that just shows that holdens are shIT
fords rock
I just wanna know how he rekons he fit a big block ford into an escort and also was able to fit 2 turbos....the big blocks barely fit in an XB falcon and also an rb30 in a datsun 1200....*facepalm* bloody kids
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
