Can anyone tell me if there are any fouling issues with the RB30 sump into a R34. The guide says that with the 32's and 33's it's fine but nothing about 34's. I won't need to drop the engine any lower either as I'm not running the standard plenum.
Send 'urtwhistle' a message, he has put an 25/30 in his 34 4-door and he is also in Perth :)
No problems with the sump clearance. I lowered the motor on the engine mounts as per R33 specs and no problems still.
  • 3 weeks later...
  • 1 month later...
Hey Guys -Firstly Great Forum, Heaps of information and has been a great help so far -120 Pages later!!
Im from NZ (Wellington) and im just about to start my RB30DET build.
I have just purchased an RB30de S2 Block , Rb25det VCT head and a Greedy Plenum -$600 total
The block was actually quite tidy for a 180k motor so the block is going to be shipped to the Re conditioners this week for New Rings , New Main bearings, New Bid Ends, New cam belt and tensioner +Relocation, 1x 1.5mm Oil Restrictor, New RB25det Oil pump and Crank collar, Rb30de water pump. Pretty much a decent refresh for the 30DET build. (factory Pistons,Rods ,Crank)
The head will maintain all its factory Valve train however will get the values refaced and reseated.
The head will also be moddified for the VCT feed
Im wanting to run with the aftermarket plenum and the standard rb25det fuel rail, upgaded injectors (600cc), FPR, 044 Intank. q45 TB and AFM, 3" inlet IC piping to FMIC and 2.5" to the turbo housing.
For the run in period im going to stick with the standard rb25det manifold and turbo. Although i wil get a GT35/40 and PFC later.
Since all this is going into a R32 GTST coupe - will i have to change my loom and ECU to an r33 rb25det loom and ecu for the run in period? Is this going to be a hassel? i know i can use an r32 Rb25de head, However as i already have a MINT VCT 25det head im keen to stick with it.
Any recommendations would be great and any ideas on how to keep the coast down for my daily driver would be awesome. I do have more cash to throw at this - However buying a house at the mo (probably bad timing on my part)
Cheers Bois!
Chad
Cheers Bois!
Chad
Don't forget rod bolts. Save up for a Link. See Geoff at Shred Ind Performance if you need help.
Cheers bubba/kiwirs4t
Yup rod bolts are a must =) , looking at getting some more info though, with the VCT do i have to source the VCT solenoid? are they easy to install? or can i just run an external feed and just plug and play? (ECU and loom) apart from that the general rb25det conversion i cant think of anything else i could possibly run into as everything should just bolt up. (might have issues with my window wipers if i change ECU) - Dont drive in the rain =)
Yea ive meet the guys from Shreds before ,and im keen for them to dyno the car when its up and running however i had plans to go for a power FC but they are all about the lInk's thats for sure. As ill be running the car in for a good 5000kms im still going to run a factory ECu and map. Eventually ill make a goal of 300kw ODD but thats much later as i really only drive my car in the w.e and will take me a while to run it in saying that.
Cheers Again
Chad
You might be able to get away with the stock ECU for a short time but RB25 ECU's seem to be less tolerant than RB20 ECU's.
When I first built mine, I ran it on the RB20 ECU for a couple of months. The only issue was the stock AFM was maxing out at about 5500rpm and it ran pretty rich.. not really what you want with fresh rings that are bedding in.
Hey guys
I was wondering about sensors and whats interchangeable? Since im putting my rb25/30 into my R32 GTS and im using the 25DET VCT head , Im wondering if all the sensors ect from my rb20de will be able to be re used on my rb30det motor?
Also im using a 25det loom and ECU for the run in period. Can someome clarify if i need to use turbo sensors or will the rb20de sensors be fine to use?
Cheers again.
You need to use all RB25DET stuff, things like water temp sensors are different, depending on series of RB25 then coilpacks and AFM are different.
Like I said, if you're using an RB25DET head, you effectively need to perform an RB25DET conversion.
If you were to use an R32 RB25DE head, then you could reuse ALL of your RB20 stuff.
Hey guys
Cheers again.
You'll need 25det sensors if using 25det computer and loom, personally I'd use an R32 gts-t loom and computer with a nistune ecu as the 25det computer can't really be retuned (will be a big issue). Use rb20/25 knock sensors, Z32 afm, S1 rb25 TPS/throttle body. Basically get a loom out of an r32 rb20det and use it.
Edited by Rolls
Bugger, so im thinking go with the R32 25 head as it will obviously be a hell of alot simpler plus i will be able to use the current RB20de for sensors and all ancillaries. What about the factory loom/Ignition coils/harness (RB20DE) ...is it much different to the r32 gtst loom and ignition system? would be gud if i can use as much as i can from the factory motor .
Sorry my run in period was probably a little far fetched. Yea im sure a drive up to Toupo would be sweet.
The Hunt for a new Head starts =) .
Cheers Boys - Your a Big Help
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
