As some people know i am working on dropping the RB30det i had in the Black R32 gts-t into a R32 gts4 with 4WD. The motor is just about ready to drop in, Just thought i'd share a few pics of the exhaust manifold i built to low mount my GT3540.
Edited by sky30
https://www.sau.com.au/forums/topic/154768-my-rb30det-into-gts4-build/
  • Replies 49
Posted Images
Very nice... :(
Got any pics of the the exh. manifold with its heatshield on?
Did you manage to get the stock heat shield fitted with a bit of manipulation or are you going to make one up?
If the stock heat shield fits its going to look almost invisible. :laugh:
good stuff carlos.
might be down next weekend
Bring your car cozza, take us for a ride, you had it back on a chasis dyno yet?
Joel:- I had a stock RB25 n/a heat sheild i bent up to make it fit. The RB25 n/a shield has thick white blanket material on the underside which should work good. I see if i got sum pics.
would of by now but thats to an engineering company in qld i now have a bend valve and a couple of chips in my piston, the collet pulled through them billet retainers on weekend. so am going through the legal process of getting it repaired. which could take some time.
Had street machine magizine ask for photo shoot on weekend too. :thumbsup:
26 head this time???, cams??, be a good sleeper this one
cheers
darren
Darren, yeah i went 26head this time for the solid lifters to allow bigger cams and the better GTR plenum.
The aim is to keep it all looking stock, similar to my black R32.
NICE!! - Would like to do this to my GTS4 as well. Maybe later this year.
Like the stealth idea with the heat shields etc.
Can you get to those Cam Cover screws?
My HKS Tubular intake makes it damn hard but possible.
Like the full polished look as well, looks trick.
What sort of price would a manifold like that be worth to buy from you?
Had street machine magizine ask for photo shoot on weekend too. :blink:
Geez... how did you manage that... lol... Long time no see, hope all is well. Wanna see the beast again :P
Geez... how did you manage that... lol... Long time no see, hope all is well. Wanna see the beast again :blink:
If it helps, blew a tyre last night doing the speed limit funny enough on the new front left tyre. Ended up with alot of hours lost, damaged radiator hoses, thermo fan had to be repositioned and wiring re-done, and exhaust re-heated and put back into shape (that was from the trailor).
Miss ya on the cruises mate, hope to catchya soon, and if you manage the photoshoot this weekend enjoy :P
Ash:- yeah, getting close, still got cams here (sitting in cupboard), just havent been to adelaide for about 6 months.
Joel:- head is only temporary bolted on ( havent done final assembly), i have blocked off the rear oil feed with a screw i made, i may be interested in that restrictor. what do you think i should run 1.8 or 1.5mm oil feed at front and rear blocked??
Joel:- I thought the 1- 1.2mm were for those running GTR or N1 oil pump, im only using a std RB20det pump, thats why i thought id stick with 1.8mm, or 1.5mm.
Are RB20det pumps same or nat as much flow as RB25det pumps?
Do RB30 blocks come std with 1.8mm restrictors??
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
