If you pass an EPA with a silencer in, youll have to weld the silencer to the exhaust so it can no longer be removed. One of the conditions of the EPA. Im sure its been mentioned already somewhere though.
Yes it has to be Spot Welded!! but it can be removed!!! its better then being harassed by the cops!!!!
Im just wondering if i have a catback exhaust,front pipe,dumpe pipe from turbo 3'inch all the way with a high flow cat, just wondering if its still legel in the streets of victoria? i know this has been answered before but i just want to make sure if its ok.
Thanks, Geraus
what about if i have a safc ?
would i get dicked ?
You will only get dicked if 1. you have something illegal 2.they find it.
The SAFC is not legal, but if they dont find it you wont get caught. What i'm getting at is take it or, or hide the shit out of it!
went today to get the epa thingo
:rofl:
i was 92db... so yeah failed.
and my safc i just didnt disconnect i took the whole thing about.. like the lcd screen and hid the mainboard in the car.
so if uze have that... try it ?
Hey guys just got my first epa letter! from the police that pulled me over...the letter states i need to get a mechanical check and a noise test.. The current mods i got so far is a FMIC return factory blitz LM and a Turboback exhaust system 3'inch with high flow cat, it ok to go the place with it on or better to take it off the blitz cooler LM? .. honestly my exhaust isnt loud. its a Trust/Greddy PE II as ppl on these fourms would even know there not even that loud...
Thanks Geraus.
Edited by geraus
Cooler will be fine as long as you dont have a pod also. Put your stock exhaust on, yours will most likely fail.
Thanks Geraus.
In other news I got an EPA letter the today, shat my pants. Opened the letter and it was only for flicking a ciggie. Needless to say I was a very happy camper, and will not be throwing ciggies around again.
Thanks Geraus.
Each time you get it tested it will generally be around $40. So you can try with your mods on but Skylines in general just pass with the stock exhaust on, so a very good chance that it will fail with your current one.
I had a look through but couldn't find any information...
What’s the deal with external waste-gates, can you have them as long as they are plumbed back into the exhaust?
I have heard mixed responses on this so just wanted to clarify.
Just another quick question, Can i still pass the EPA test with my stock catback but still have my 3inch front trust/greddy pipe and turbo dump pipe?
bceause i just connect my catback to them. Its not that noisy but just to make sure.
Possibly but unlikely. If you had a full 5 inch straight through off the dump pipe with no cat or resonator and it was below the volume limit, you would pass. It doesnt matter on the equipemtn for that kind of test, rather the volume of your exhaust. So you can try with your current stuff on, however you are looking at roughly $40 per test.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
