thats all to technical for me, so for an idiot help me out... why do they check hieght with the wheel on say the front bar? if it relates to axles..
..and yeh im not smart with this technical shit before someone becomes a smartass :)
The axles rule is just the "lowest point"...
Generally a front bar is within the restriction distance so its 100mm.
Usually the only place that can be lower than 100mm (how low depends on the calc's), is usually around where your CAT would finish.
It's a very small section.
Obviously the above is super generic, each situation is different.
Make better sense?
im about to go get my car tested/fixedc. But i am confused and want to know all the information before i fork out my money so...
its an Rb25det, R34. so 90db @4800rpm max legal...
when it was tested it got 89-91db @ that, but bounced up on 'deacceleration'...is that a problem? or am i just being screwed by the system??
i mean if its legal @4800...whats with getting busted when its de-accellarting at some other RPM??
thanks
So after spending hours reading this and other threads, EPA documents and the tealeaves of some long lost Chinese tribe, I'm still totally confused about what you can and cannot do.
From my reading, it seems like basically ANY mod at all is pretty much illegal EPA wise, BUT, in the EPA 06 document it says:
Any modification is permitted provided that it can be
shown, by way of test1 or engineering reason, to
show that the modification would not be expected to
cause an increase in emissions beyond a similar,
unmodified vehicle.
So does that mean with an ADR compliance thing or engineering cert, 'ANY' mod is actually OK?
I'll list some mods/reasons/questions to be more specific:
- Intake manifold/plenum - There are a hundred threads on here about how to modify stock, put in plasmaman/greddy etc, but is any of it actually legal at all?
- POD (dry) is legal, but not with any change to intercooler. But what about those in an airbox, because again, 100 threads about how to do that and questions about that
- FMIC/SMIC, as above really.
- Injectors? EPA says "Extra or larger fuel injectors are not permitted." so not that they could actually tell without pulling them out, but they are still illegal right? So the 100 threads talking about them, all illegal?
- ECU, again says not permitted, unless to meet ADR.
- Turbo changes, doesn't actually talk about that much in terms of changing the size/CFM/PSI etc, just that external wastegate not permitted (and therefore majorly reducing the number of turbos available). Highflowing is impossible to tell, but is it actually legal? What about changing other aspects (impeller size/type, housing, etc) but still keeping an internal wastegate? Again, 500 threads on this, but is any of it legal?
- Exhaust manifold, seems to be all OK to mod this, ie stick in 3" dump pipes, as long as doesn't break any other rules.
- Exhaust cat and back, again legal as long as isn't too noisy, still maintains the same catalytic quality etc?
- Boost controller, probably belongs with ECU, but illegal? How do make use of your fancy new highflow without one?
As I said at the start, it seems all of this CAN be done contrary to all of that document saying NO NOT PERMITTED, so long as ADR/engineering certs are gotten? Is that right?
Basically, at the end of the day, I'm asking, what mods can be done legally, and how do you go about it (actual mod, as well as the legal aspects)
I know 95% of you guys just do it yourself or take to your local mechanic, without even looking at the legality, but a few like R31Nismoid have actually gotten damn close to following the law 100% and still making major power.
As a side point, how do performance shops like Dr Drift, Mercury, etc do modifications that majorly increase the power, ie 300RWKW etc, when all/most of the mods are illegal EPA wise? OR is this not the case because they are legit/engineer approved places? IE, can you have mods done at these places and it is legal?
Edited by Thelen
Totally depends on the year of being made.
As you said Alex - pre 1983 cars have different rules, there are also cars that do not require CAT convertors and so on due to age etc etc.
HOWEVER should you put say a RB26 into a Datto 180b - you would need to comply with the MOTOR's emission requirements, not the cars.
It's very much subjective to the situation - if you can provide more detailed info we could help futher :D
well, i own a s14 which was sold in 1995. so do i have to follow the ridiculous new sounds restrictions (90db) or the restrictions when the car was released? which was probably 96db.
unmodified vehicle.
That is more in reference to replacement parts.
ie. injectors non standard or aftermarket AFM, but ALL very close to the factory specifications.
In the event that say Nissan discontinue manufacturing or something.
Engineers certs do not cover all emissions testing in Vic unfortunately, EPA has some grounding.
Most of the answers are in this thread mate...
Plenum - Illegal
POD - Illegal (unless 1 intake mod)
FMIC - Illegal (unless 1 intake mod)
Injectors - Illegal, given you need aftermarket ECU to run them...
ECU - Same as above.
Turbo - Impossible to tell a hi-flow, illegal but cannot be checked. Larger than factory turbos are illegal either way.
Exhaust - Manifold is fine
Exhaust - Could be 5" for all it matters, however MUST be within noise restrictions
Boost control - Illegal. Allows you to increase boost
You can get all the above legal - IF you go through ADR testing and its within limits.
Issue is to get that approval is a $3000 test, and if you fail, you don't get a refund.
OK, as I said the answers are in the thread, I already said/knew that they were illegal, what I was getting at is how it is done legally.
Aside from the $2-3k testing, there really is no way to get EPA legal mods of the above done?
So basically 95% of the posts here are illegal lol? Well, not illegal, but clearly the owner/modifier isn't following any testing or anything :)
I guess just have to live with the risk of fines from EPA to see any/much increase in power without just buying a plain faster car :)
Just spoke to *** at RE customs, and don't quote me or him on it, but he said people just do the mods and if they get done replace with stocks and get it all cleared. Seems a bit ridicules to do this, even more so that EPA isn't more proactive (not that im saying they SHOULD enforce the law more lol, just saying they do a pretty shitty job), but whatever TIA lol.
So looks like I'll just have to suck my balls in and hope they don't get snipped by a cop and sent to teh bad house.
Edited by Thelen
I know this sounds like a small thing.... but best I check...
I've changed the number plate light on my R34 to a white LED (T10). I'm aware any other colour is not allowed.
Is this allowed? Reason I ask is because it doesn't seem as bright as the original (T10) incandesent light.
Plenum - Illegal (unless 1 intake mod)
1 intake mod??
You have this regulation from the EPA modification guidlines wrong if you think you are only allowed 1 intake modification.
You can have as many intake modifications as you like provided they meet the requirements unless you have an aftermarket intercooler which in the case of an aftermarket intercooler it is the only modification that you are allowed to have.
Mofied plenum chambers are not legal under any circumstances without ADR approval.
your post didnt make much sense to me, how can you have more than one if you can only modify the cooler but nothing else thats 1..
if u put a pod u cant have the cooler, and your saying u cant have a plenum regardless so how do u have as many as u like?
1 intake mod??
:action-smiley-069:
Intercoolers that are larger than standard or have a different mounting location or are added where none were originally fitted, are permitted only if no other changes to the intake system have been made. In other words, you may have a pod filter or modified/added intercooler, but not both. Any sensors integral to the original intercooler or intake system just be retrofitted and be in the correct location.
Modified or aftermarket plenum chambers or throttle bodies are not permitted.
Document is here: EPA Guidelines (2006)
So guess what, given you only have a 1x Airbox, 1x Intercooler, 1x Plenum on pretty much every EFI car... What's left to change exactly? Painting the piping pink?
And you are only allowed to change two of those 3...
On top of that you are only allowed to mod one...
Guess what that leaves us with to do?
You are only allowed to make... 1 intake modification.
That's so dumb coz that's where speed bumps will rip the exhaust off! Is there a maximum height that speed bumps are allowed to be? haha
I know there is some sort of ADR around having the plate lit up for the obvious reasons, unsure if the actual amount of light is specified though.
I've never really looked into something that trivial :action-smiley-069:
How far that goes to get you in trouble or not i wouldn't be entirely sure either.
I know you can be defected for one that doesn't work... but given yours works... even if it wasn't inline with the rules totally, should be ok.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
