Read the 3rd post.
It has a link to the documentation. Sorry but I'm not going to give you the answer when it's clearly provided like that.
I did. Have read that document a hundred times and it doesn't have the answers I'm looking for. I have two pre-76 cars I'm planning on modifying. That document only goes back to '76. It'd be good to know what is legal before I go doing engine swaps and other, obvious to spot mods.
  • 1 month later...
Just wondering whats the rules and regulations about having a surge tank, are they illegal full stop no matter where they are? I want to put mine where the spare tyre compartment is and probably replace that wood cover with a sheet metal cover which I will bolt there to cover it to try keep the smell down and also safety since the battery is in the boot. And also what are there restrictions for track scruitenering is it only not allowed to be in your boot if you have a hatch without a separete boot like on 180s?
Surge tanks are fine. For being street legal you have to obey the following:
As long as they are in a vented compartment, which can contain a fire if a fitting comes loose and drops/sprays fuel everywhere.
If you put your surge inside your boot, you must have a box surrounding it, ideally made of metal, with venting to the outside world.
Race application is different, and I wont comment as I have always had a 'street legal' car so never worried about scrutineers.
Cleared my Noise EPA on friday. Sunday did my gear box, Monday i get a FULL EPA letter. whistling.gifkill me.
Anyway, read almost all of the 43 pages, same questions popped up 20 times so im a bit nervous about asking this one... but i think ill fire away anyway...
My question is:
Clearly PFC and Injectors are not allowed, but i had a guy tell me that they didnt check and he got away, with everything else being stock. Has anyone else had similar experience where the guys didnt check ecu or do they usually check?
Ive pulled out my boost controller, pod, exhaust etc just wondering do i have ANY chance of should i not even try.
Full EPA? Don't risk it.
I've seen them open the ECU cover, unplug AFM's, use the consult port etc. All of which will give you away mate.
They also know the colour of stock injectors.
It's your call either way as it is totally luck of the draw.
Ohh not the answer i was hoping for... o well pull em out i guess.
Thx for superfast answer
Ive had full EPAs twice and they ripped out the kick panels checked ecu checked injectors and everything so its really a 30 dollar gamble so if you fail you have to pay 30 again to get it retested.
Might risk it just cos im lazy. Got plenty of time to go again and pass if, and when i fail. Lol
problem with being lazy is - it goes down on your file.
if you get pinned again, and again with the same mods... you better stock up on lube as they can cancel your rego and make the car unregisterable as just one possible outcome.
always pays to go in standard without one iota of ammunition for them
didnt think of it like that, oh well.
What is the best way to pass "CO" test..."idle" and "high idle"?. max is 4.5% i had 4.6 on idle and 5.8 on high idle.spank.gif
Got a letter in the mail about exhaust been too loud :( and need to take it for EPA!!!!!!!
question is, i have a pipe through the cat and what do i have to do to bring it back to normal?
Any help please??????
A stock GTR exhaust rarely passes - a clear example of how stupid the EPA laws are. I mean a 100% factory GTR, is over the limit. Full of shit this state.
So you'll need
1x factory cat
1x factory exhaust
1x baffle plate (just a metal plate with a dozen small holes drilled into it
Then you'll pass no problem
So you'll need
1x factory cat
1x factory exhaust
Thanks R31Nismoid
I wonder where i can get these now :(
bloody stupid law...when the compliance is done, do they do the exhaust sound test?
SSV did my car compliance when i first bought from them...
  • 3 weeks later...
Got EPA a while back. might as well write up the story.
Got a letter in the mail, some EPA car bitched. I found it amusing considering i had just put on a new muffler that was quieter then my practically straight pipe i was running beforehand.
So, found a stock s14 exhaust and stock cat. The owner said the stock s14 had the original resonator replaced with something better. Awesome, every bit helps.
Replaced the exhausted, realized I had leaks coming from the front of the car. Fixed a large front pipe leak but I could now hear leaks coming from the engine bay.
Thought my manifold had cracked, only choice was to remove the entire turbo, check the manifold and all the gaskets.
Asked for an extensionand got a 1 week extension.
Removed everything and found that my last exhaust manifold stud had broken off in the head. Paid for something to drill out the stud.
Bought a standard manifold and started to put everything back on the car only to find I managed to damage the thread of the turbo oil line on the block cuz of the banjo bolt.
Asked the EPA for an extension and got a 2 week extension after writing a letter.
Tapped the damaged thread and bought a braided oil line. Fixed all the leaks between the exhaust sections.
830am on a saturday got a test.
Passed on 85db.
The tester draws a diagram of the exhaust and writes down what he thinks he standard or not. He had a question marked over my cat.
Tips to pass, stock system. 90db is quiet as. No leaks. Tester didn't check emission control systems.
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
