They have ECU controlled values. Therefore they are legal.
Which is the bullshit part of the Victorian law - you can have a ECU controlled valve from the factory - but cant install one aftermarket... :rolleyes:
Just to confirm - police can tick major and rwc for any defects yes? I was fairly sure it's completely discretionary, but just wanting to confirm.
It use to be that they needed to find 3 defects for it to be a major but i dont think that exists any more, either that or like a lot of other things they vic pol do they just ignore that and do what they like.
When i was defected they only picked 2 things and made it a major.
He got me for 2 things without even opening anything (too low (he got under the car and measured) and bald rear tyres (camber wear)), even as he handed me the fine he pointed out that the steering wheel was illegal (momo race), if he had have had a look inside he would have found the boost controller and hand controller for the power fc, some times your just better off to cop it sweet cos it could get a lot worse!
Edited by W0rp3D
Apparently getting an EPA in the mail sometime soon after tonight... Manual boost controller, intercooler+pod and possibly exhaust, heres hoping i dont.
"It looks a bit low"
"....LOL its stock height"
"Yeah but what about the exhaust"
"....it's the same height as stock"
Meanwhile my cars parked in 25cm high grass..
It's how I bought the car, I wouldn't be stupid enough to put it in plain sight where the previous owner has an would have kept the stock airbox but I suppose you always get caught out in that week where you say "I'll fix it tomorrow"
Hey guys just purchased a GTR from SA (yay) now I got it mechanically looked over everything is great apart from brake pads and discs needing to be replaced and just a few minor things..all of it im going to fix..i just need a leeniant rw tester just to transfer it to vic. So if anyone can help me out with someone they know please.
Thanks james
If it's stock just go anywhere.. Not really any 'lenient/dodgy' testers anymore
You should be ok if it's transferring to your name as opposed to clearing defects
Good luck
Mmm I know what you mean but after chasing a rwc to sell my last car..i took it to 3 different ppl and they all picked on different things literally :/
so just want to see if anyone here knows anyone.
Selling a car and transferring it into your name are different things, if you let them know your intentions they should be a bit less fussy as you will be driving it and it won't come back onto them for not being tough on the rwc.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
