It's not 75%
It's a set RPM determined by the EPA - which is more than that.
Either way, you need to be 89dB @ 4900rpm - that includes on back off/rundown. Which is usually what trips the meter.
Unless you have a stock exhaust, you'll fail.
My memory is hazy on this, but I thought it was around 60% of peak RPM (based on the factory limit) at 500mm at around 45 degree off axis with minimal reflective surfaces during the measurement (the meter must be away from reflective surfaces.)
Can't remember where I had this information though, so not 100% sure it's right...
EDIT: actually I thought it was 50% of max rpm...
Gotta find the EPA doc...
Edited by wht510
Well.. If he said you'll get it in the mail - guess what? You'll get it in the mail :merli:
You really need to have a read of this thread. It'll give you a fair idea of what you need to change.
You'll only need to change the things that can be picked up. ECU is obvious, you already know that. So what else does the ECU control? Injectors, AFMs etc. Only stock items can run on a stock ECU etc.
It's not 75%
Unless you own a gtr which when it rolled out of the factory in japan was over the 90db limit for Australia ... go figure that one out.
A while ago i read there was specific areas that are exempt from height rules, from what i read it was a meter either side of the axles, downloaded the mod guide from vic roads to check and there is nothing in there any more, it is a new one too, october 2011 is the date on it now.
Last time i looked at it exhaust manifolds were free as long as all the original fittings were retro fitted, now you need to have documents from the manufacturer to say that the manifold you are using is suitable for that car/engine, im glad my chinese stainless manifold cracked and i went back to standard.
seems things are getting worse
Edited by W0rp3D
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
