i was planning on putting a DVD player in the upper glove box also
i was thinking of not disconnecting the stock DVD rom unit, but just re-locating it backwards under the dash somewhere. i have no needto access it, it just has to be there behind the dash
then i can put a DVD player in teh stock nav position!
thats what i was thinking of doing before chris releases the final build of his satnav/dvd/radio kit
chris' kit is not going to have DVD
from what he has told me it is GPS navigation ONLY
that means we need a separate DVD solution
there are a few units on eGay that have DVD and a TV tuner in them for $250-300ish.. that means all you would need is a TV antenna (can hook into the stock one?) and bob's your uncle - TV and DVD to go with chris' GPS unit and you have all the stock features accessible through remote control and the steering wheel
some of the DVD/TV units on eGay also come with a remote infrared attachment so you can leave the unit under the upper glovebox and access it hidden for that stock look :P
the plug an dpay version is for the nav. I can do the whole lot turn key but not without having the vehicle to do it.
considering these cars (or the ones I have seen.) didn't have DVD as std its not a major issue. if you do not have the reversing camera - go in there and use a 'mod' lead to make it work.
we need to talk :P ring me in the morn.
hey mate, will call you in the afternoon as i have a session in operating theatre in the morning and i can't take a phone in with me
what is SWC? (from your other post)
Edited by WazR32GTSt
Could someone help a girl out?!!! lol.. i have no idea how to do these things.. Frank, when u get urs sorted.. would u be kind enough to show me?..
location?
I would like to say that whilst the R34 one is different.
I ripped all my stuff out after testing the front audio and video input on the xanavi satnav in the R34.
it worked for the laptop when switched to NTSC.
then i got told there is nothing else i can do.
I ripped it all out.
looked in the boot when i finally got to the sub install and the fricken tv tuner part ALSO had an AUXinput.
a fricken HTPC in there would have worked out great guns.
I am hoping if the V35 has something similar which it sounds like from IT doctors post.. then there is certainly some scope for it all.
Honestly don't know yet, I'm trying to figure out why you would need video out on that connector, for I'm pretty sure that is the remote camera hookup, as when i disconnect it, only the backup camera stops working. TV is still there. Whereas if I pull out the big connector the TV stops working, so this is the connector to splice... i think...
I've taken proper photos of that board now, but too busy this weekend to do anything.
Oh yeah and I've got a cable with connector that isn't hooked up to anything dangling up under there, next to the sub wiring. Do you guys have that too?
Might need a new thread purely for people that are interested in working together to build an aux-in connector and keep the whores out.
Thanks for reply.
As my understand, your one come with reverse camera, so you only have one empty connector isn't hooked up to anyting.
Can I ask: there are 4 connectors on TV unit, the big one for TV, and two grey ones for antennas, so the last one stay in the middle of that three is for camear?
my one doesn't come with reverse camera, so I got two cable connectors hangup there. both in grey color. I guess one for camera the other one is something else.
AS IT DOCOTR said:
He run a connector via that 6 pin connector to get a set of AV input--which in your car is used for camera? after reading post 199, i thing it is a pretty easy job expect no idear of VTR- used for.
OK then, yes my car has the camera, and that white connector on the board you are referring to is plugged in on mine. The only reason I'm thinking not to run a splice from that particular connector is that on mine I'll only get input from it if the car is in reverse. I'm not sure yet where that switch is made. Whereas the TV one works all the time. IT Doc, do you have to press the TV button on the front to see your MP3 player? When does it work?
Like I said haven't had time to play as yet, so we'll figure it out together soon.
Very interested in knowing what that other unplugged cable is for. I may ask the US guys if that is the sirius connector or if they have it at all.
Edited by -= SKiZO =-
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
