  • Replies 75
Posted Images
0KM/H...
Haven't hit the track yet...
But in a months time I might get to around 60-80km/h on the track (Skid pan WOOT!)
And I'm thinking of doing drag day the day after, so hopefully then aronud 170-180km/h...
ON M5 IN SYDNEY EVERYNIGHT WITHOUT FAIL FROM KING GEORGES ROAD TO HUME HWY 320KPH+ IN MY GTR TO GO SEE MY GF.
MAY BE STUPID MAY BE WRONG BUT I DO IT. ALL THE TIME.
LOTS OF PEOPLE TO BACK UP MY WORD ASWELL.
Edited by GTRGTR
You sir, are a tool! :D
i got bout 190 in 4th @ about 5800rpm on a private road. stil had plenty left and another gear.. nothing on other ppl tho i kno..
What diff do you have in the car? That doesnt sound right???
My best is 227km/h at Phillip Island. That was read off the Pfc that read 114km/ at 110km/h. So its probablt only 220km/h. Sad thing that is coming onto the straight at 190km/h. So that long down hill straigh only nets me about an extra 30km/h. I need more power :D
I might have got the RPM wrong there... i think it may have been a bit higher then...lol but i was in 4th
original diff so i was wrong dammit
Yeh but i got to 11ty billion m/s on the m3 going to see my man friend at the northern polar regions of mars. I do it every day swear to god. Weevil will back me up. I lol'd so hard a 320km/h that is for girls. Maybe this should be moved to wasteland.
Edited by ScorpR32
yor so awesome and dont give skyline enthusiasts a bad name at all!
^^^ i love that
any way to somthing constructive does anyone notice anything strange when on a track doing 180km/h? ive found car feels good but it starts to sound like the doors are about to fall off. i know this may be the door seals but ive been in plenty of imports that whisle just doing 100km/h and for mine i need to be doing 180.
i also have a 260 or 280 cant think nismo speedo in my 32 but still have the speed cut in it. i find it gets to 190 to 200 before backing off. its also auto and has heaps of legs left in it as i find it will still drop back a gear if im doing 150 in over drive.
also when is that over speed chimer in the car ment to kick in??? i thought it was ment to be around 100km/h? but mind does nothing till 150.
oh and i forgot to mention if i hit power in my auto at 180 it gets completly 90degres to the road. lol
