gday guys, just curious as to what type of standard parts you are using in ya car if it is making big power. say 300rwkws+
things like standard pistons, rods, rings, water pump, oil pump, cams etc.
cheers james
https://www.sau.com.au/forums/topic/158510-big-power-using-standard-parts/
well my car was running 12psi 55oc inj's, and exhaust making around 200 awkws. including a oil restrictor and newer oil pump.
when it died that is.
Edited by Turbz_13
  • 3 weeks later...
this is all good to hear, i have had my rb26 rebuild with eagle rods and acl pistons and rings but using a new standard r32 oil pump(early) and was looking at bigish kinda power. say 350awaks
Rebuilding your engine for that kind of power and not upgrading your oil pump/oil pump drive is crazy and now leaves your new engine with a serious weak point
Agreed, adding to that water pump, tensioners etc etc
the engine has the lot exept the new oil pump, well it does have a new pump. just an OEM one. i was running out of fund with the rebuild rather quickly so an oil pump like a nismo, trust, jun etc was out of the question.
wasnt too keen on the n1 as i have heard about 50% of them that are installed seem to fail, (i have heard this not saying its the truth or they are bad or what every). which actually turned me off the path of using one. so rather than wasting the cash having everything prep'd for an n1 oil pump and it failing the standard pump was decided. as im not looking at increasing the rev's over 7500. it was always out of the question in my mind to increase it that far.
eventually if i decide on going big power. ie 400+kws at the wheels i will have to budget to replace my oil pump with a decent name one. and i guess then i will need my crank collared as well. so im guessing another engine out job. so 5k for the lot this time?
Edited by Turbz_13
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
