Who has dyno print outs to support these claims, id like to see some concrete evidence.
If you have them post them up.
i have the GTR proof that shows it is just as capable. i wont go as far as saying one is better than the other because i do both and both do the job admirably.... what i dont accept is people rubbishing the EMU and making rash statements that it wont match PFC.... cause i see it it match pfc all day everyday. Proof in the pudding is greddys 1000ps emu powered GTR.
  • Replies 765
Mt Isa ???
Geez mate who out there has been swayed away from Power FC
But yeah Ill take you up on that offer for sure
Do you have any idea as to when you may be heading up as it is already almost later in the year
Ive still gotta get my injectors and Poncams before the tuning starts
but if you head up before the poncams then so be ill tune without them
And a MAP sensor=)
Are there inputs so I can get signal from afr and egt etc?
Can I shange the boost with it?
Are the original knock sensor good?
how much do greddy map sensors cost? assuming they don't come with the 'kits' supplied by Slide?
to get the afr you need the afr adapter kit, but that also means you need a wideband o2 sensor.
hang on what's afr adapter kit and when do you need it? + wideband o2 sensor!?? sheesh, maybe this whole affair isn't really cheaper than a power fc
meaning ur able to use a wideband too see if the car is lean or rich. the adapoter ables to read from the wideband o2 to do data loging. the innovate ones are bout 600 i think???
does anyone know what settings to use to get a signal off the knock sensor?
what board is yours (little letter on the top of the circuit board) is it (d) (e) etc? only the later boards have knock display.
you need the same thing to tune a PFC..... if you not tuning it dont bother as you tuner has one.
mine had an (E) on it.
sweet and is the serial over 4500? if so all you need to do is use the settings in that RB26 file i sent you as it is perfect for RB's :P non-resonant (7.02 kHz)
whats 'over 4500' mean? where do i find out?
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
