Hi!
I wanted to ask some questions about the setup I want to buy.
1.Innovative LM1 or LC1
2.EMU
3.GTR harness ? Or plug and play ?
4.A/F harness or pressure sensor for Innovative ?
I got hcr32 rb20det wired in my x-carby a31 car. I want to be able to do road tuning on my own. So I want a wideband to work with EMU and emu to act as a datalogger as well. So when I do some road tuning I get all the needed parameters datalogged by EMU and then make adjustments to the maps. Can it be done ?
Thanks!
Edited by robots
  • Replies 765
yes that what u need. The innovative 02 is what im running in my seris 1.5 skyline. The gtr harness will have to be modified to make it a gtst harness the wires that need to be cut are on the first pages of this thread. can get both the presure sensor and the a/f harness so u get correct boost pressure and the a/f with be on the emange data logger screen. And it can be done road tunning just make sure you have enough points on ur licences to do it lol :-)
ive heard conflicting opinions on the innovative wideband's. something about them needing recalibration every day, and that the plx wideband's were the way to go. they even come with a little gauge.
the e-01 doesnt work with the ultimate. according to URAS, greddy are releasing something similar for the e-01 sometime into the future for the ultimate.
Edited by SECURITY
had no issues with my LM-1 from innovate. had it for 3-4 years..... sensors last pretty well, about the same as any other and are available anywhere ($90-120) as the are just a bosch.... PLX and Innovate use the same sensor :D part number 0258007057
Heya Torentski,
I don't have an ingriss manual on me only the jap one therefore I have a silly question :D
Can I run low impediance GTR injectors on my R32 RB20DET engine with the ultimate "without" the use of a resistor pack?
I was thinking (dangerous I know) of selling my denso 550cc high impediance ones and getting some Blitz GTR injectors and it would be handy not to have to wire in the resistor pack.
cheers
-Jez
Heya Torentski,
cheers
-Jez
Nah you need to stick with the factory impedance, or wire in the resistor pack :domokun: easy if you have a plug and play loom ;)
With some feedback from http://www.emanageforums.com/ I found the source of my ignition timing problem (ie EMU reading constant 111.0deg in data logging). The problem is the cam and crank signal wires in the Install Manual and the plug and play loom are the wrong way around. Apparently there is an updated install manual which makes note of this but i'm yet to find it.
Unfortunately for me it didn't fix my car idling/running rough but it's progress :)
With this change I repeated troubleshooting including changing RPM Signal and reinstalling EMU software/firmware but no change. I have the injector adapator for 6 cylinders on it's way so will see if this helps.
Wegs
Unfortunately for me it didn't fix my car idling/running rough but it's progress :worship:
Wegs
sorry i thought i posted this up somewhere?? bugger as the JDM plug and play looms for series two S14 do the same thing unless swapped around to the differrent (aus spec) wiring.... much like s15 PFC pin swap.
as far as running rough have you taken the lag time out of the inj settings yet?
Trent
How much lag should we be taking out
just go .1ms at a time till it stops idling rich ???
delete lag times in the before and after, so it shows nothing.
I have noticed that the input and output voltages for the afm are different. The emanage outputs slightly more voltage than is coming in....
At idle there is about 0.03 to 0.08 more volts. I think if the voltage is different, and im running standard injectors and afm, that its going to cause problems with the standard ecu trying to compensate fuel and timing?
Should the afm map be adjusted in its entirety to reduce the voltage back until the input and output match at idle?
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
